Home > Wheels & Tyres > TPMS |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I have just acquired a new set of wheels and it looks like they are fitted with TPMS.
18th Apr 2013 9:34am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Post 2006 vehicles will recognise new TPMS sensors, but you need to go for a 15mile drive. Not sure about pre 2006. This does assume that the batteries in the TMPS sensores have not gone flat. I think ther may have been a change of sensor around 2010 and I don't think they are compantible with 2006 to 2010 system. I think the 2002 TPMS system uses different sensors to the 2006 onwards. 56 TDV8 Vogue SE
18th Apr 2013 1:17pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Put your spare on as a road wheel first, it will/should self-learn all new sensors fitted to an axle on the 2006-2009 system, mine did. Then put your spare back in the boot and put your 'permanent' road wheel back on.
19th Apr 2013 7:11am |
Fitted all five wheels yesterday and went for a run but nothing happened.
19th Apr 2013 8:24am |
Nothing appeared on the dash at any time so I reckon the car has not detected the wheels.
22nd Apr 2013 9:42am |
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 |
Ian, just to clarify, is the TPMS warning light illuminated on the dash? 2007 TDV8 Vogue SE Java Black |
22nd Apr 2013 9:48am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Is TPMS a nuisance on an already complicated car ?
22nd Apr 2013 11:07am |
If your buying brand new next time, you'll probably find it is.
22nd Apr 2013 2:44pm |
No warnings on the dash and no menu option to change the pressure setting.
23rd Apr 2013 8:22am |
It looks like you have the TPMS disabled. You would have a low pressure warning light if it was enabled and the sensors weren't recognised 2007 TDV8 Vogue SE Java Black |
23rd Apr 2013 8:38am |
