Home > Technical (L322) > Fuel pressure problems - 2003 TD6 3.0. |
So just to recap,
10th May 2013 2:33pm |
Ayrshore Member Since: 09 May 2013 Location: Ayrshire Posts: 4 |
Fuel pressure reading at all times is just over 1 bar - 1.05-1.1. Only time it got higher was when I added an extra electric pump before the fuel filter, then it read 3 bar.
10th May 2013 3:54pm |
do you get ANY pressure at all on the high side while cranking or running on easy start? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
10th May 2013 4:11pm |
Nope. It never goes much above 1 bar. |
10th May 2013 11:29pm |
http://www.fullfatrr.com/gallery/albums/us...elling.pdf
11th May 2013 10:51am |
I've already replaced the HP pump with a good used one.
11th May 2013 11:07am |
You have to suspect the rail sensor then TBH.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
11th May 2013 11:14am |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
You need to know the low pressure reading.
11th May 2013 11:34am |
Motoroffice Member Since: 28 Apr 2016 Location: Braga Posts: 3 |
Hi,
13th Sep 2017 7:06pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 73 |
Ayrshore, you do know the TD6 has 3 fuel pumps, don't you?
30th Sep 2017 5:09am |
mariner30 Member Since: 12 May 2016 Location: SW Scotland Posts: 17 |
Had exactly the same problem last week. Changed no2 pump - all good now. 2003 TD6 SE model with EGR removed
15th Nov 2017 11:40pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
No 2 pump direction ok? 2010 3.6tdv8 180k km.
16th Nov 2017 8:24am |
umitbat,
17th Nov 2017 2:27am |
