Home > Technical (L322) > Engine Management Light + engine temp |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I wouldn't think the aircon should affect it appart from engine loading. When mine was on LPG the Revs would drop as the clutch on the AC compressor engaged. The ecu knows when this is due to happen and gives the engine an extra bust of fuel to stop this happening. On the LPG it caused the dip due to the calorific value being less on lpg than petrol. They are very clever engines.
21st May 2013 7:24pm |
Morango Member Since: 19 May 2013 Location: Glasgow Posts: 21 |
Ill go check this right now. But I was assured when I bought it that these 'breather hoses' (that's what he called then) were all replaced,
21st May 2013 7:31pm |
Do you have any Landrover specialists by you? Might be worth speaking to the garage you bought from and see if you could talk them into letting a local indy look at her? offer to throw £150 at it for diagnosis etc as it's cheaper than£ 300 in fuel back top Essex? Just an idea. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
21st May 2013 7:38pm |
Hoses checked and they seem fine. They even still have the paperwork attached to them and its clean so that's an obvious sign they are new to the untrained eye I suppose.
21st May 2013 7:58pm |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 |
Hi Ross
30th Jul 2013 9:03pm |
Hi,
30th Jul 2013 9:32pm |
Excuse the spelling and grammar above. Bloody iPhone!
30th Jul 2013 9:34pm |
Good to hear! Hope mine is also relatively small bills Alcohol and eBay is never a good mix
30th Jul 2013 10:17pm |
Today the engine light appeared back on. Unread the code and this time I only have P1172 on its own. Nothing else this time. I am out of warranty in 4 days with no chance of getting back to Essex.
1st Aug 2013 4:45pm |
According to the wiki that code is :
1st Aug 2013 5:48pm |
Problem is finding the air leak that's causing this.
1st Aug 2013 6:03pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Does the car have a standard air filter or has this been switched to K&N? 2009 Vogue TDV8 Nara Bronze
3rd Aug 2013 5:59am |
It has the K&N fitted because of the front end conversion. 2002 / 52 Range Rover Vogue 4.4V8 with 2012 front end and rear light cluster conversion. |
3rd Aug 2013 10:35am |
There's your problem. With these filters the engines often throw up faults as this engine was never designed for k&ns. Mine has done the same and the light will come and go. 2009 Vogue TDV8 Nara Bronze
4th Aug 2013 8:43am |
