Home > Technical (L322) > door lock |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
the cable from the door handle has broken. ... - .- -.
8th Aug 2013 8:00pm |
Al ajv8 Member Since: 19 Apr 2013 Location: middlesbrough Posts: 20 |
i can open the door with the handle its just when i turn the key to unlock nothing happens is this the cable |
8th Aug 2013 8:05pm |
fiddly job...there are 2 cables , 1 from the outside door handle to the lock and 1 from the inside handle to the lock...do a search ,there's a few threads re this. ... - .- -.
8th Aug 2013 8:14pm |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 |
There's one cable from interior door pull to door latch and one from the exterior door handle to the door latch. if you arent seeing the door lock pin on the door card pop up and dowm with your key then something wrong with the key barrel rod/bar.
11th Aug 2013 9:31am |
Thanks fixed it, it was the bar from the lock barrel not located in the lock mechanism, no need to take the door card off, there is a gromet on the side of the door which conceals a screw whch holds the part of the handle which has the key in, once undone it just pulls out, when refitting just make sure the bar locates properly. |
11th Aug 2013 7:20pm |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 |
I had a similar problem but was a broken lock mechanism! Not the cable... i paid a lot just for the lock!!! Ex-FULLFATTY now downgraded
12th Aug 2013 1:11am |
