Home > Technical (L322) > door lock
Al ajv8
door lock
Just tried to open the door using the key, turns both ways but nothing happens, locks ok with remote, any ideas is this an easy fix with the door card removed.
Post #202982 8th Aug 2013 7:18pm
the cable from the door handle has broken. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #202985 8th Aug 2013 8:00pm
Al ajv8
i can open the door with the handle its just when i turn the key to unlock nothing happens is this the cable
Post #202987 8th Aug 2013 8:05pm
fiddly job...there are 2 cables , 1 from the outside door handle to the lock and 1 from the inside handle to the lock...do a search ,there's a few threads re this. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #202988 8th Aug 2013 8:14pm
plumajp
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
There's one cable from interior door pull to door latch and one from the exterior door handle to the door latch. if you arent seeing the door lock pin on the door card pop up and dowm with your key then something wrong with the key barrel rod/bar.
There is a bar that goes from the lock barrel and locates itself into the lock mech. When You twist the key it twists the lock mech.
I forgot to locate mine when swapping door locks and had the same problem.
If you haven't fiddled with you door lock I can't see how it's broke though as the bar can't easily come out unless you unbolt the lock mech and drop it down.
It is plastic so may have snapped.
10mins to take door card off And peel membrane back to peek up with a torch.
Post #203393 11th Aug 2013 9:31am
Al ajv8
Thanks fixed it, it was the bar from the lock barrel not located in the lock mechanism, no need to take the door card off, there is a gromet on the side of the door which conceals a screw whch holds the part of the handle which has the key in, once undone it just pulls out, when refitting just make sure the bar locates properly.
Post #203488 11th Aug 2013 7:20pm
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
I had a similar problem but was a broken lock mechanism! Not the cable... i paid a lot just for the lock!!! Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #203549 12th Aug 2013 1:11am
