Home > Technical (L322) > Suspension again |
I have heard of the odd problem with the height sensor "flipping the other way". Better have a look at all the sensors also also if there are no leaks, cable/connector issues. Maybe the off-road extension and then subsquent access height has done one of the sensors in ?? MY 2010 5.0 SC Galway green and sand interior!!
14th Sep 2013 10:32am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1504 |
Eugene, you beat me to it!
14th Sep 2013 10:37am |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
The reason I didn't think that a height sensor had failed was because the car stayed at the right height on all 4 corners although the compressor wasn't appearing to work correctly, I thought that if a Height sensor had gone then it would give an error? I haven't selected the off road navigation screen as I have got the DVD nav and I don't think that's available on it. 2002 Vogue Epsom Green with Ivory Leather.
14th Sep 2013 10:53am |
Do you think there may be a valve after the reservoir that has stopped working and therefore not letting any new air into the system stopping or nearly stopping any additional raises of the suspension? 2002 Vogue Epsom Green with Ivory Leather.
14th Sep 2013 10:55am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
What are you using to check for error codes?
14th Sep 2013 11:52am |
I haven't managed to read any fault codes yet. Strangest thing is that although there is a height change request going on (orange light flashing) the compressor doesn't keep running. It runs for a little while and then stops. I am guessing that it stops because the air reservoir is full but why doesn't the air go to the struts? 2002 Vogue Epsom Green with Ivory Leather.
15th Sep 2013 8:23am |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
do you have genuine 2002 compressor
15th Sep 2013 8:43am |
Yes, it's genuine. This fault has just materialised. I guessed at lack of output from the compressor so changed the piston ring and its certainly blowing now, just no actual suspension movement. 2002 Vogue Epsom Green with Ivory Leather.
15th Sep 2013 8:52am |
Get the faults read
15th Sep 2013 9:16am |
Cheers for that, I guess you might be right. Have to bite the bullet and spend the £400. 2002 Vogue Epsom Green with Ivory Leather.
15th Sep 2013 9:18am |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
You could try and unplug the compressor from the system and temporary feed it 12v, see what it does, but getting the codes read is going to help most of all |
15th Sep 2013 9:58am |
Hi Paneldamage
15th Sep 2013 10:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16257 |
Error codes are the way forward... Cant do much more without them pal |
15th Sep 2013 10:45am |
Do you get error codes if its the compressor failing? Or just ECU or height sensors 2002 Vogue Epsom Green with Ivory Leather.
15th Sep 2013 10:47am |
