Home > In Car Electronics (L322) > Retrofiting a Bluetooth ULF Module |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
You will need the antenna to pair, as the ULF will not have a bluetooth signal otherwise.
29th Oct 2013 7:49pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I've just been and collected the antenna, cable and microphone from my local bmw dealers.
1st Nov 2013 7:11pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Good news Andy
1st Nov 2013 7:19pm |
Cheers Andy. I re-pinned it slightly to correspond with your chart- I think two wires were different to the chart I originally followed from L322.com.
1st Nov 2013 7:27pm |
The last bit of the pairing procedure states to turn ignition off.
1st Nov 2013 7:59pm |
I know nothing about Navcoder. For example, how do you connect to the vehicle? |
1st Nov 2013 8:11pm |
Sorry, I'm not on my pc and have no idea how to cut and paste on a blackberry tablet.
1st Nov 2013 8:42pm |
Just had a look at those cables and they look like my RSW solutions cable. Could I not use that with Navcoder? |
3rd Nov 2013 3:41pm |
My rsw cable didn't work, think that's specific to all comes
3rd Nov 2013 4:11pm |
I'll have a look later, thanks.
3rd Nov 2013 10:28pm |
That's the correct place for the antenna.
3rd Nov 2013 10:36pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
My ULF was mounted on the outside of the amp bracket. I had to remove the Amp & bracket, then drill a couple of holes in the bracket, mount the Amp & ULF before installing the bracket back in the vehicle.
4th Nov 2013 1:49pm |
If you just put pin 32 to 36 nothing will happen. It needs to connect whilst 36 is still connected to the ULF and earth.
27th Apr 2014 3:17pm |
Big_Al Member Since: 10 Sep 2014 Location: Essex Posts: 12 |
Hi anyone know if Baris is still selling a bluetooth adapter harness for L322 |
12th Sep 2014 11:12am |
