Home > Maintenance & Mods (L322) > How to add LED lights?
PJS
Thinking of adding some LED lights, the ones that are bright and "sexy" like in the new Audi's. Not sure if i will as i think it may look cheap, but if i was to, how would i connect the "9 - 14V DC" PVC LED lights to the battery etc. Thinking of putting them on the front.
Post #22048 10th Jul 2010 10:58pm
daveo
i, i have changed all my bulbs to led's " the ones that can be changed any way" when it comes to daylight running led's it will be a hard one to pull off, you could make it look cheap or your self a boy racer..
but if you was going to go down that road i think you would have to go for the lover grills, look at the merc's or if you could get hold of a pair of head lights you could fit your own inside them and that would look propper..
but all the same would like to see what you come up with.. V8 facelift Range Rover Autobiography 22" wheels.
Post #22071 11th Jul 2010 11:07am
PJS
Well im only thinking off adding some strips, separate to the actual headlights. I think it will look abit cheap and tacky though, so im in two minds. Just thought it would look quite good at night (next.. neon lights, haha joking)
Post #22082 11th Jul 2010 1:11pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
LED strips will look cheap IMHO but some of the LED bulb changes look good
Post #22134 12th Jul 2010 11:27am
Fox
I think LED strips will look chav-tastic. Shocked But then again, it depends how they are done I guess.
Post #22136 12th Jul 2010 11:30am
Full fat not diet
Strip lights look fine on an R8 or a New E Class but looks after market on older cars and cheapens the look
Post #22139 12th Jul 2010 11:42am
+1 Thumbs Up All my spelling errorz are belong to me!
2023 FFRR L460
2020 Range Rover Velar
Post #22141 12th Jul 2010 11:49am
PJS
I was thinking it would look quite cheap, i saw some on a range rover and it did look hawt! Anyways, i dont think ill be bothering.
Post #22178 12th Jul 2010 5:54pm
@pjs... first post so please be gentle....re drl's, i have at the moment a s-max and have replaced the fogs with smd's [leds] and wired to a drl control box [off ebay] so when the car is turned over the smds come on and when the headlights are switched on the smds go off....the s-max fogs ,as would be the ffrr fogs ,are ideal to convert to drl's as front fogs in the uk dont help much in foggy conditions and are not a legal requirement for mot's...
btw , i'm looking for a rr to replace my s-max , so hopefully i will become a fully fledged member soon....
Post #22244 13th Jul 2010 8:00pm
daveo
hi, do you have any pics
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #22246 13th Jul 2010 8:29pm
here's a 'how to' which i posted on the s-max forum, hope it helps.. http://www.smaxownersclub.com/forum/showth...ing-Lights
Post #22247 13th Jul 2010 8:37pm
daveo
after-market led daytime lights
&feature=related V8 facelift Range Rover Autobiography 22" wheels.
Post #22361 14th Jul 2010 10:14pm
the trouble is dave that if you dont fit the 'add on type' leds properly and in the right position , they will look tacky...the beauty of my s-max/fog install is that it looks like part of the car..
Post #22371 15th Jul 2010 8:20am
M44K TS
Personally, I find some LED DRL's a bit tacky when they're not supposed to be there, even some OEM ones look a bit odd to me. I much prefer the likes of Mk6 Golf's where they use the main beam dimmed. Incidentally, I went onto Navcoder yesterday and enabled the DRL function on my car, got the main beam on 25% brightness dring the day, then they go off when the headlights come on.
Looked a bit odd at first but I quite like them, might set the brightness to 35% though as they look a little yellow. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #22397 15th Jul 2010 1:33pm
i totally agree re the add on leds looking tacky...the audis with the leds in the headlights and like you said the new golfs , look ok...
btw , how do you connect navcoder to the ffrr...
Post #22400 15th Jul 2010 2:20pm
