Home > Technical (L322) > Coolant escaping from coolant cap |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
it could be the right time to change the thermostat, should a correct cap not sort it. fairy liquid suds on paintbrush is a quick leak detector, to save you burning your earhole -should it vent in anger!
1st Dec 2013 5:35pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
if the radiator is getting hot and the engine temp is not rising above 105 degrees would this not indicated the thermostat is working correctly?
1st Dec 2013 6:28pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I'm no expert but i seem to recall hearing that a HGF under rare circumstances may exhibit signs of allowing combustion gasses into the coolant (but not oil) thereby raising the pressure in the system.
1st Dec 2013 7:10pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Katash, you are correct HGF can happen between cylinders and water galleries, cylinders and oil galleries, oil galleries and water galleries or all 3.
1st Dec 2013 8:38pm |
i am thinking of getting one of these kits to just try and rule out any gases in the coolant, has anyone ever used one on the M62 engine before?
1st Dec 2013 10:21pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Matt. I wouldn't get a kit. I had a test done soon after I got mine. The result from the garage was not good, but had no signs go HGF. 3years later and still no issues. Apparently the chemical fluid can degrade over time??? I would get a proper test with a propper gas monitor. Might be something to do with the coolant being glycol based? Just my 2p worth. I would put the right cap on first then see what happens. You may find once 200 cap fitted you get other water leaks due to the increase in pressure and age of coolant system. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
1st Dec 2013 10:48pm |
I'm ordering the 200 rated cap from BMW tomorrow as land rover don't supply it. I have replaced the majority of the cooling system over the last 3 years.
2nd Dec 2013 12:00am |
I wouldn't lose sleep yet. The facts are the car runs well and is showing no physical signs of HGF. You do have an underrated pressure cap on your tank which is leaking. Work with the facts and not what ifs. I never got the HGF thing out of my mind and took a lot of joy out of the car. Dont go down the same road I did. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
2nd Dec 2013 11:34am |
have fitted the 200 rated cap, will see how it goes
2nd Dec 2013 8:42pm |
just to follow up, I do have the 140 cap I checked top and underneath yesterday. mines ok. (2002 v
3rd Dec 2013 10:19am |
texpis Member Since: 29 Nov 2010 Location: Stockton-on-tees Posts: 53 |
So did the 200 cap work? I am haveing simulate problems and mine has a 140 cap from landrover.
7th Dec 2013 5:47pm |
yes so far so good, no over pressurising no leaks
8th Dec 2013 8:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34939 |
good job Matt ... - .- -.
9th Dec 2013 11:34am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi Matt, still no worries since you fitted he 200 cap? what year is/was you 4.4L V8 please? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
12th Mar 2015 1:01am |
