![]() | Home > Technical (L322) > Deployable side steps not deploying. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8483 ![]() ![]() ![]() |
Just a guess but press and hold the retract button? Works for the sunroof...... There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 ![]() ![]() ![]() |
Battery reset? |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
It sounds like your steps are turned off. Here are the operation instructions, try the very last bit.
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 184 ![]() ![]() ![]() |
This is so embarrassing. Thanks for the tips. I should have tried the obvious first!
Out of interest, how does the above procedure work on a post 09 car without a key? |
Good question, I don't really know as I have never played with one. I would presume that like with other manufactures there is a way of selecting the aux ( position 1 ) and ignition (position 2) using the stop start button, maybe without putting your foot on the brake pedal and holding the button for a number of seconds, this is the procedure in our Volvo. MY2007 S/C - Stornoway / Jet |
No sir, ign on or engine running... No ign 1 & 2 |
Looks like my steps were turned off and once I re activated them according to Jon's instructions, they are working again!
