Home > Technical (L322) > Speedo |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Can't see it being the speed sensor on the wheel or the instrument pack would behave normally, but wrong - ie it would record mileage and average speed at 50 mph. Also the steering will be pretty heavy as the servotronic unit will think you are doing 50.
9th Apr 2014 7:37am |
pete Member Since: 08 Apr 2014 Location: Bedfordshire Posts: 11 |
Hello Thanks for the reply
9th Apr 2014 12:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
you cant go wrong in trying a battery disconnection, details are in the wiki.. ... - .- -.
9th Apr 2014 12:59pm |
Thanks I will give that a try I looked at several eart points and they looked ok but I will take them apart when I do a battery disconnect. I will check alternator first as well as reading your forum suggests they are very sensitive Electrically. |
9th Apr 2014 2:46pm |
I meant was the speedo working correctly before you send the instrument cluster away for repair.
9th Apr 2014 3:07pm |
Also, you can access the hidden BMW test menu by using the procedure below.
9th Apr 2014 3:21pm |
Thank you very much for your replys
9th Apr 2014 5:41pm |
Hi
9th Apr 2014 8:15pm |
I'd say the instrument cluster has failed the self test then, mine goes all the way around and then back again.
9th Apr 2014 8:31pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Just be aware, the dash binnacle is a one hit wonder... i.e. you cannot reprogram me it into another car once it has been programmed. |
9th Apr 2014 8:41pm |
Thanks for the replys
9th Apr 2014 9:07pm |
Ah, so you can't replace it with a unit from a scrapper, or even substitute it to aid fault finding ?
Ouch
9th Apr 2014 9:13pm |
Yes, unfortunately you VIN lock them when you programme them. So, no you cannot test it with another... |
9th Apr 2014 9:21pm |
