Home > Maintenance & Mods (L322) > Start of big bills? |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 |
Hi
24th Apr 2014 8:47pm |
Thanks for the tip mate.
24th Apr 2014 9:48pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
The pipes are normally joined together at a T piece with some sort of jubilee clip. Just test that they are tight and haven't eased off . |
24th Apr 2014 9:57pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
There are loads of places for leaks to appear without leaving much evidence (water boils off) before even suspecting a headgasket. I've had a few leaks on mine that took awhile to trace (2002 4.4 V8 like yours) but never once would have suspected the headgasket. I've had a headgasket go on another car and it's pretty obvious in most cases when they have gone. It's a bit irresponsible of the garage to worry you over a headgasket if they haven't tested it for exhaust gases in the expansion tank, excessive steam coming from the exhaust or contaminated oil/coolant. |
24th Apr 2014 10:01pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
If the coolant system is pressurised and a head gasket failure is suspected all you have to do is get a "sniff" test carried out.
24th Apr 2014 10:07pm |
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 307 |
My LPG V8 had the same problem when I first got it. Would lose the coolant over a period of a week, took it back to the garage twice and they discovered that when the engine was cooling down after a run the pipes that were cut for the lpg system (sorry no idea what they were or are called) would contract allowing coolant to leak. Something to do with the T piece someone else mentioned. Easy fix and not a problem after. Wish I still had that car |
24th Apr 2014 10:18pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
check your bolts on the water pump too, I had 1 bolt that was loose but the main cause for leaks for my ff was the o ring on the 4 way t piece just under the rad.
24th Apr 2014 10:44pm |
Ragerover Member Since: 02 Feb 2011 Location: Newcastle Posts: 220 |
Check it's not from the aircon
24th Apr 2014 10:51pm |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
Check also the coolant reservoir - sometimes can get hairline cracks in the expansion tank - thats where my coolant leak was coming from.
25th Apr 2014 12:34am |
v8rich Member Since: 28 Dec 2013 Location: Healing, Lincolnshire Posts: 67 |
I got a kit very similar to this http://www.ebay.co.uk/itm/230723938073 to check where my engine was leaking.
25th Apr 2014 1:30am |
