Home > Maintenance & Mods (L322) > Start of big bills?
jaipal2004
Start of big bills?
Hi
Following what I thought was a coolant leak I took the car into a local garage this morning. They ran some checks and couldn't replicate the leak and even said the system was pressurised.
They think it could be head gasket related??! Naturally I'm worried and wondered if there is another cause?
The garage is local so not sure if the leak only manifests itself after a longer drive?
Any words of comfort?
Car is a 2004 Vogue V8 that's been LPG'd
Sad
Post #255958 24th Apr 2014 8:47pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Just tracked mine down to the water pump. 2003 4.4 on lpg. Also worth checking the water pipes where they have been cut to take the lpg regulator feed from.
Post #255966 24th Apr 2014 9:23pm
jaipal2004
Thanks for the tip mate.
Would that affect coolant level too?
When I examined the leak on my fingertip it was watery with a slight red tinge
Post #255972 24th Apr 2014 9:48pm
DaveK
The pipes are normally joined together at a T piece with some sort of jubilee clip. Just test that they are tight and haven't eased off .
Post #255976 24th Apr 2014 9:57pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
There are loads of places for leaks to appear without leaving much evidence (water boils off) before even suspecting a headgasket. I've had a few leaks on mine that took awhile to trace (2002 4.4 V8 like yours) but never once would have suspected the headgasket. I've had a headgasket go on another car and it's pretty obvious in most cases when they have gone. It's a bit irresponsible of the garage to worry you over a headgasket if they haven't tested it for exhaust gases in the expansion tank, excessive steam coming from the exhaust or contaminated oil/coolant.
Post #255978 24th Apr 2014 10:01pm
If the coolant system is pressurised and a head gasket failure is suspected all you have to do is get a "sniff" test carried out.
This simply checks for exhaust gases discharging thro the coolant. Not absolutely 100% foolproof but a very good indicator in most cases.
Post #255981 24th Apr 2014 10:07pm
chawks
United Kingdom 2002 Range Rover HSE 4.4 V8 Alveston Red
My LPG V8 had the same problem when I first got it. Would lose the coolant over a period of a week, took it back to the garage twice and they discovered that when the engine was cooling down after a run the pipes that were cut for the lpg system (sorry no idea what they were or are called) would contract allowing coolant to leak. Something to do with the T piece someone else mentioned. Easy fix and not a problem after. Wish I still had that car Big Cry
Post #255982 24th Apr 2014 10:18pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
check your bolts on the water pump too, I had 1 bolt that was loose but the main cause for leaks for my ff was the o ring on the 4 way t piece just under the rad.
This would only leak when cooling down when engine off, a common fault for the FFs. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #255989 24th Apr 2014 10:44pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
Check it's not from the aircon
You often get water dripping from there Growing old is compulsory Growing up is optional
Post #255991 24th Apr 2014 10:51pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Check also the coolant reservoir - sometimes can get hairline cracks in the expansion tank - thats where my coolant leak was coming from.
Also some places can put die in the coolant to see where its coming out - usually highlights any issues with joints somewhere. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #255999 25th Apr 2014 12:34am
v8rich
England 2002 Range Rover HSE Td6 Bonatti Grey
I got a kit very similar to this http://www.ebay.co.uk/itm/230723938073 to check where my engine was leaking.
Not sure if it was that seller though.
Post #256002 25th Apr 2014 1:30am
