Home > General > Scary Mileage? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
To my mind, the diesel BMW unit is the most reliable unit fitted to the L322. They are well proven across the BMW models as well, though thankfully it doesn't have the dreaded swirl flaps fitted in the rr. Main reason I chose it over a petrol. Less to go wrong - some may argue, prob whilst leaning against a petrol pump.
13th May 2014 7:56am |
TD6 is very reliable but the GM box is more likely to need a rebuild post 120k. |
13th May 2014 8:11am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
It is not the engine that is the problem. Worry more about the rest of the running gear:
13th May 2014 4:07pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Awesome guys. Thank you! Least I know if it's got plenty history 130k+ ain't the end of her life! |
13th May 2014 4:15pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Big mileage doesn't necessarilly equate to unreliability, lack of maintenance does Got - 2017 SDV8 Autobiography in Loire Blue
13th May 2014 5:38pm |
Or this theory ;
13th May 2014 5:42pm |
Or it should have already been replaced by that time! Got - 2017 SDV8 Autobiography in Loire Blue
13th May 2014 5:54pm |
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 |
I've only had my '03 L322 for 4 months and clocked up 5,000 odd miles in her to date...but I must add I drive the living daylights out of it..both on its own and with a trailer. The BMW M57 is an excellent unit and good for hundreds of thousands of miles. The GM transmission is actually pretty decent....it's the torque converter that isn't man enough for the job. The air suspension, calipers, suspension bushes, electronics etc are wear and tear items....no better or worse than any other German car I ever owned. I actually rate these cars as pretty tough...but it is important to have a good independent workshop who these cars inside out and can keep them performing without charging the heart out of you. 2008 Range Rover TDV8 435,000kms
16th May 2014 11:20pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
They are solid cars and as long as you look after them they will last you a lifetime.
17th May 2014 9:58am |
Thanks guys for all the input.
17th May 2014 10:31am |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 302 |
Just checked mine there. She's on 181,000 miles.
21st May 2014 4:34pm |
alexoconner Member Since: 13 May 2014 Location: Houston, Texas Posts: 24 |
Mine 2011 has 128,000 and still going strong. No issues at all, as long as the maintenance has been done thoroughly it should be fine. But suspension is a thing to worry about. Current Cars -
21st May 2014 11:40pm |
oop north Member Since: 29 Mar 2014 Location: Preston-ish Posts: 18 |
Sorry to butt in on someone else's thread: Is there a scary big service bill at any particular point? I know on th discovery there is a big service at 105k miles - is it the same on tdv8?
24th May 2014 8:38am |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
^ Answering the above . . . yes & no !
24th May 2014 9:21am |
