Home > In Car Electronics (L322) > My hybrid tv tuner problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34950 |
press auto and it should come up with a channel list, if it doesnt move to a different location....although your house might get digital via a roof aerial the FF needs a strong signal to work.. ... - .- -.
15th May 2014 4:19pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Have done all that though.. No joy. Well annoyed |
15th May 2014 6:32pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
It's worth going into the boot compartment (N/S) and check then re-check every single connection on ALL of the modules in there..... 2006 4.2 SC
15th May 2014 6:36pm |
I'll check again but I wouldn't get static screen if it was connected properly..
15th May 2014 8:53pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
As a test try connecting up to your house aerial (easier said than done!), then at least you will know if it is a signal problem or a tuner problem..... .
15th May 2014 8:59pm |
i still think that you should try and find a very strong signal area....the old analogue was different in that a weak signal could be picked up and you would get a fuzzy picture but you dont get that with digital ,its either received or not.. ... - .- -.
15th May 2014 9:03pm |
I don't have terrestrial tv in me home, only sky..
15th May 2014 9:15pm |
So I think I have figured out why the tuner won't work. Ireland uses mpeg4 for digital tv whereas uk uses mpeg2.
19th May 2014 12:11pm |
i thought mpeg4 was for hd broadcasts and mpeg2 for sd broadcasts..
19th May 2014 12:55pm |
done a google and found this,
19th May 2014 1:02pm |
We use mpeg 4 for sd whereas uk use mpeg 4 for hd. I think uk will be catching up in few years and changing to mpeg4, but at the moment it causes a lot of trouble for us in ireland. Lot of tvs and digiboxes are bought from uk suppliers and people have been stung to find that the equipment won't work here
19th May 2014 1:03pm |
apparently freeview HD tuners will work over in southern ireland [i think] but that doesnt help you unfortunately..
19th May 2014 1:08pm |
Thanks for that stan |
19th May 2014 1:09pm |
have you RSE lolo?
19th May 2014 1:20pm |
