Home > Technical (L322) > 2006 L322 - Radio, GPS and related Failure |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 302 |
Anyone? |
30th Jun 2014 10:43am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Hi,
30th Jun 2014 11:16am |
thanks for your reply. Surely, that however would not stop the GPS Unit from ejecting the CD? This leads me to believe it's a power or grounding issue. Finding information on the topic is extremely difficult. |
30th Jun 2014 11:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34960 |
try a battery reset peter, details are in the wiki..
30th Jun 2014 11:57am |
Hi Stan,
30th Jun 2014 12:19pm |
it sounds like a complicated problem...i fear that it might be a dealer visit to determine this cause..
30th Jun 2014 12:26pm |
Just realised when one reconnects the battery the Land Rover Display is activated for maybe 2-3 seconds. It really is a strange one. Will keep you all updated when and if it get resolved.
30th Jun 2014 7:08pm |
If the nav unit has failed it will break the MOST loop and also prevent the DVD being ejected.
1st Jul 2014 8:50am |
Hi Guys.
8th Jul 2014 12:15pm |
Read thru my post above and check the points off but it sounds like a most based unit has failed. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
8th Jul 2014 11:44pm |
Thanks. Will give it a go and let you guys know how I get on.
8th Jul 2014 11:47pm |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 |
Why does everyone think a battery disconnect will fix problems ? if its broken it needs fixing sorry to get angry but fed up with reading crap advice from forum leaders who should know better! Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
8th Jul 2014 11:55pm |
The BT module is a common one failing and it indeed breaks the MOST daisy chain. On my 4.2 they just took both fibers out of the connector and taped them together "looking at each other" thereby restoring the loop. That worked.
9th Jul 2014 12:02am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
BT module is a favorite as its on the top of the pile (& gets wet first!) Does sound like an odd problem though as normally they get stuck on the Land Rover screen.........
9th Jul 2014 12:08am |
