Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
see this page for how to program the key and install the chip
28th Aug 2014 10:58pm |
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 |
Lastly , Done
29th Aug 2014 12:27am |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
started to install this tonight and have an issue with the connector this looks like the one supplied pulled the one out of the amp and the tunner and there is no way they will fit so is it the wrong one ??? or am I looking in the wrong place ???? paul |
5th Sep 2014 8:39pm |
It plugs into the radio plug, radio is the small one furthest into the boot and furthest towards the middle of the car, I removed the plastic panel on the boot floor that the removable boot floor sits on, remove the tie down strap in that corner, then the two net hooks on the rear piece (they twist 90deg to remove) then remove small panel that runs up the inside of the boot opening, remove net hook at bottom of subwoofer cover, then boot floor plastic is three 10mm plastic nuts.
6th Sep 2014 6:08am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
6th Sep 2014 8:25am |
All
6th Sep 2014 5:11pm |
Not happy
7th Sep 2014 7:48pm |
You need a 5 meter aerial lead and a fakra convertor to sort the aerial out, there is a standard plug in the back of the new unit, but the aerial is in the boot.....
8th Sep 2014 8:55am |
8th Sep 2014 9:29am |
for anyone else with one of the Android units who is having a few issues
9th Sep 2014 12:39pm |
Nilrem Member Since: 17 Aug 2014 Location: Portsmouth Posts: 7 |
@Haylands I have an '02Vogue with DSP and would like to mirror your install but add the TV tuner.
9th Sep 2014 9:04pm |
Sorry, never noticed your message
11th Sep 2014 6:40pm |
Hi mate,thanks for replying. I'm down south in Portsmouth.
11th Sep 2014 7:32pm |
I went through Erisin themselves, I think easyriding sell their stuff...
11th Sep 2014 11:58pm |
