Home > In Car Electronics (L322) > No beeps from rar of car when caravan attached |
philmc79 Member Since: 10 Sep 2013 Location: Hyde Cheshire Posts: 94 |
I have changed the wiring from a 7 pin socket to a 13pin euro plug using a proper wiring loom from Land Rover and removing a generic wiring loom since doing this there is no beeping when the indicators are activated as it did on the generic loom, is this correct or have i missed something on the installation on the proper loom?
15th Oct 2014 8:06pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
I have standard 7 pin OEM electrics on my 2007 and there's never been a beep on indication... GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
15th Oct 2014 8:17pm |
Thanks for that i was just checking i think the old one prob did it as a confidence thing as the car does the checking for you.
15th Oct 2014 8:19pm |
Aftermarket looms often contain a buzzer whereas the factory one does not. As long as you have the green trace light on the dash everything's OK |
15th Oct 2014 8:21pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
As others have said, you don't get the beeping as you have the telltale on the dash. The proper way that it should work.
15th Oct 2014 8:47pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Tell tail on the dash????????
16th Oct 2014 12:08am |
It all depends on how your trailer setup is set in the ccf.
16th Oct 2014 1:26am |
I don't get the trailer light, and having read the destructions there is no reference to the little green trailer, I will have to delve deeper into this. It does every thing that is listed, and I've had no problems, I wonder if its a plug'n'play thing, and the light gets enabled at the stealers. Did you have yours programed at the stealers or is it a plug'n'play? Yesterday I couldn't spell Engineer... Today I are one!
16th Oct 2014 10:08am |
Mine, like most, was plug and play as I got the twbar a good two years before I got my faultmate. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
16th Oct 2014 10:11am |
Sorry if I made things more confusing Paul, I don't think our early cars have the green tell tale, its the later ones I believe, like philmc79 has.
16th Oct 2014 10:39am |
Does that mean that I should stop looking for it? I was beginning to think that it lived in the sump, because I couldn't find it any were else
19th Oct 2014 11:12am |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
Hi on 2006 model. There is a green light in dash panel that comes on when you plug trailer in just stays on to let you know trailer plug is attached. Earlier car the light flashed with indicators . Cars have. Landrover wiring kit fitted |
21st Oct 2014 2:13pm |
