Home > In Car Electronics (L322) > Accessory +12v Purple / White on cassette?
http://www.ebay.co.uk/itm/Add-A-Circuit-St...486426a3ec
Post #289275 27th Oct 2014 9:14pm
miggit
And Yes its going in the far right of the screen on the dash, stuck to the black bit that doesn't come out with with the cow covered bit. Personally I look over that bit when driving, might not be so good if you look through the steering wheel when driving! Yesterday I couldn't spell Engineer... Today I are one!
Post #289276 27th Oct 2014 9:15pm
mjdronfield
What about the light switch or fog light feeds, that are only a few inches away ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #289278 27th Oct 2014 9:21pm
miggit
Ok so is fuse 7 empty, without having to brave the could to see? if so I can just plug the live feed wire into the fusebox with a lucar connector, the wire to the monitor already has a fues in it. Yesterday I couldn't spell Engineer... Today I are one!
Post #289281 27th Oct 2014 9:27pm
miggit
The light switch isn't !??! its a canbus switch, I unplugged it when I had it all apart for the hands free kit and the headlights came on ?? plugged it back in and they went off ! That confused the Censored out of me! Yesterday I couldn't spell Engineer... Today I are one!
Post #289282 27th Oct 2014 9:31pm
mjdronfield
You know I wondered that after I posted....not got RAVE handy Embarassed
Best use the fuse feed then - should be able to hide most of the wire under the dash top if you remove it. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #289287 27th Oct 2014 9:52pm
If you just undo the bolts across the top of the dash and the ones under the speaker grille you will be able to feed a wire from the speaker to the front of the dash by the windscreen, saves taking the side bits off.... Pete
Post #289290 27th Oct 2014 9:56pm
miggit
Right then you lot, WHO forgot to say that you have to remove the air vents and corner trims from the dash to remove the cow covered top Evil or Very Mad
There I was happily removing bolts across the dash top, went to remove the top and it wouldn't move Confused , maybe its stuck... NO, I now remember why I had to remove the drivers end cap and the light switch.... Someone at Land Rover thought that it would be funny to put 2 screws under the end caps to make any easy job hard Censored Censored
Anyway the outcome was that I fed the wire across the top of the dash, and dropped it down the side of the govebox, and fed it into the fuse box from the nearside. This also meant that I could use the earth point under the kick panel in the passenger footwell. I fitted a 15 Amp Lucar (spade) connector and plugged it into fuse 7, and it works!
I would have used 1 of those piggy back fuse things if the monitor didn't have an in line fuse, but as it did already have a fuse fitted it seamed like overkill to have 2 fuses in the same line. The only downside to this is if a fault were to develop I will have to remove the Censored dash corner trim to change it.
And whilst going across the dash, I did contemplate the keyhole surgery wire feeding with coat hanger, and while it looks very possible, it does require a lot of blind luck to get your wire where you want it. And the way the Great God Sod has been watching over me lately, I could foresee it being a SHOCKING experience Shocked
All I've got to do now is fit the senders in the wheels, and I'm waiting for the nod off a buddy of mine to bring it up his workshop, when he's got time. Yesterday I couldn't spell Engineer... Today I are one!
Post #289545 29th Oct 2014 2:13pm
mjdronfield
Oh no ! I did think you knew to be honest. It's in RAVE and Pete said in the post above that it saves taking the side bits off.
Sorry chap. Took mine off as the top was not flat over the middle and the worst bit is unclipping the tags in the vents.
At least it's sorted now.
Have you pics of the setup ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #289548 29th Oct 2014 2:17pm
miggit
As mine have been in and out so many times they don't really lock now Smile
The passenger one is really easy to remove, but the drivers one is a wee pig, but I have now found that you can get a finger or 2 behind it when the end panel has been removed. You know to give it a bit of a shove and encouragement, like saying move you Censored
Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #289549 29th Oct 2014 2:26pm
miggit
Sorry no pictures, we've had this conversation Mark, my Box Brownie isn't computer friendly Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #289551 29th Oct 2014 2:32pm
