Home > Wheels & Tyres > Pirellis or Michelin
Page 1 of 3 123>
corinthian99
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Evil time has come to replace the rear no brand crap rubber - night drive across Cornwall in the rain was a bit squirrely last night. Local tyre place in Falmouth has given a price of ฃ165 for Pirellis Scorpions or ฃ169 + ฃ50 rebate card for Michelin Lattitudes. Prices are each, fitted inc. VAT.
Whats the group opinion?
My current stuff are 255/55/R19 - does that sound about right?
Post #292074 10th Nov 2014 9:22pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
IMO, Pirelli Scorpions are the best tyre money can buy for normal, every day use in the UK that you can put on a FFRR.
Michelin Latitudes or Continental Cross Contacts are a close second.
Post #292087 10th Nov 2014 9:52pm
mjdronfield
Goodyear wranglers on mine. Never had an issue, neither for 4 years with them on my Disco 2.
I rate Goodyear with the pirellis and Michelins as premium...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #292092 10th Nov 2014 10:10pm
miggit
I've got pirellis' on the front and general grabber at's on the rear, which are fab! I'd stick with the pirelli if its only ever going to see tarmac, I've always found the michelin a bit nervous in the wet, but they do last! Yesterday I couldn't spell Engineer... Today I are one!
Post #292095 10th Nov 2014 10:18pm
Got lattitudes on the ffrr, and they do last well, and hve been fine in terms of wet and dry handling, have wranglers on the disco, also good! And scorps on the disco 18" which are also fine tyres. Personally think the scorps edge it, but the wranglers are rated well over on disco4.
Pays your money takes your choice. what is on the front? There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #292122 11th Nov 2014 12:06am
corinthian99
Iota, but they've got a good bit of tread left so they can stay for now.
Post #292123 11th Nov 2014 12:12am
IMHO you should never mix rubber - same tyres all round.
Post #292143 11th Nov 2014 4:41am
miggit
Not exactly correct there bud, don't mix crossply and radial tires, and having the same make on the axle helps, and obviously the same size. Which in the case of a FFRR, being a full time 4x4, all the tires must be the same size all round. Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #292200 11th Nov 2014 2:25pm
sometimes its not practical or affordable to have all the same , certainly roughly the same depths and same makes on each axle is advised.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO ฦŽ๊“•โˆ€๊“•O๊“ค PICS
Post #292202 11th Nov 2014 2:33pm
I think Alistair is trying to point out that as you need to run all the same sized tyres on a FF, running Grabbers only on one axle could mean (as the treat is deeper) a larger rolling circumference on one axle than the other...
I certainly would not run a completely different type of tyre on one axle of my FF! Thumbs Up
Just my humble opinion Bow down
Post #292205 11th Nov 2014 2:37pm
miggit
Unnecessary quote removed
If the tires are within 5mm of each other you will not suffer any ill effects, it not a vauxhall 4x4 Turbo (everything within 2mm). Otherwise you'd have to change all the tires every time you got an un-repairable puncture, that would make things very expencive.
The General AT's aren't a very aggressive tyre with super deep tread, the AT2 however is. And if I were to fit something like the Cooper STT's that are on my Jeep (the real thing, not a miss quote), I'd have to fit the same all round, they're over 20mm of tread!
And Craig, buddy, tell me more about these 'Deep Treats', I'm all ears Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #292209 11th Nov 2014 3:07pm
Pirellis or Michelin?
Pirelli Scorpian Zero Thumbs Up Thumbs Up Thumbs Up
Post #292224 11th Nov 2014 4:09pm
Andy B
As Gaz said Thumbs Up Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #292310 11th Nov 2014 9:43pm
I wasn't referring to the law - just my opinion - for me it has to be the same rubber & tread pattern all round - I wouldn't mix brands
I know many people do, but i learnt from expensive experience that they have different handling characteristics and behave differently - and I know the FFRR isn't a sports car, but I just can't help myself Embarassed
I also wouldn't run below 3mm even though the law says 1.6
You pays your money......
Post #292327 11th Nov 2014 10:18pm
Im also getting a little more picky about tyres as i get older/can afford not to put spandex radials on my cars.
wouldn't go as far as to swap the whole set if just one axle was worn but will not go below 3mm, and would always try to have the same tyre on all 4 corners where ever possible.
Im good for a little while in the ff as these michelins seem to be pretty much indestructable in terms of tread wear. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #292332 11th Nov 2014 10:23pm
Page 1 of 3 123>
