Home > Technical (L322) > steering rack replacement ?
gpzjamie
United Kingdom 2006 Range Rover Supercharged Supercharged Santorini Black
Hi, just had my 05/06 rr 4,2 sc in for its service at a local independent, i asked them to investigate a slight wobble on the steering post 50mph, they said it was wear on the steering rack, and a new one was £1800, i have looked one bay for recon units, is this a big job or a straightforward swap ? thanks,Jamie jamie
Post #293264 15th Nov 2014 8:52pm
Discotigger
Check the connection of the steering column lower universal joint to the splined connection on the rack is tightened up properly first , as this is a common reason for steering wheel play.
On the steering rack replacement, if done 'by the book' it is a pretty time consuming job, requires the engine mounts disconnected and the engine lifted to give the room to get the rack out.
However, a good indy (or good main dealer) can remove the old rack and fit the replacement without the hassle by taking the tie ends of the rack, jiggling out the old rack and fitting the replacement rack in sections.
If you get a second hand rack of the fleabay, it can be a good idea to fit new cooler pipes, tie rod ends, track rod ends, tie rod end boots and servotronic valve prior to fitting. These bits are relatively cheap and will avoid any problems with the second hand rack.
You should be able to get a rack off the fleabay for around £200, so a massive saving on the £1800 cost of a remanufactured unit from the dealers.
Post #293272 15th Nov 2014 9:27pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
My gut intinct would be to get a 2nd opinion before you go further.
.. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #293276 15th Nov 2014 9:32pm
steering wobble at 50mph is normally tyres need balancing... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #293280 15th Nov 2014 9:40pm
Certainly worth exhausting every other avenue first sir Thumbs Up
Post #293283 15th Nov 2014 9:49pm
Never heard a rack give those symptoms, if the rack is worn it will have play in it, that you can feel at rest.
As the rest say.... get a 2nd opinion and get all the suspension arms and bushes checked... Pete
Post #293287 15th Nov 2014 9:55pm
Would be supprised if it was the rack internals, more likely inner tie rods or one of the suspension bushes, racks aren't cheap but are available second hand, though I would have thought you may be buying as many problems as you have now.
As has been said, check all other possibilities first, before plunging in as you will be really hacked off if it's not the rack when all said and done! There is nothing that can't be fixed with a hammer😜😜
Post #293292 15th Nov 2014 10:03pm
gpzjamie
thanks guys, I've had the wheels balanced, it is a bit better, i will see how she goes for the next 500 miles or so, and maybe its time to find another specialist ? thanks again .J jamie
Post #293324 15th Nov 2014 11:33pm
Were all four wheels balanced or just the front two? If the rears were balanced too then swap the fronts & rears around and see if that helps Thumbs Up
Post #293325 15th Nov 2014 11:37pm
do you have standard LR wheels or maybe 22'' aftermarket ones, they could be the reason for the wobble... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #293329 15th Nov 2014 11:58pm
gpzjamie
just running the standard 20' wheels, she has 135k on her but until this has been as tight as a drum, time will tell i guess ? jamie
Post #293346 16th Nov 2014 12:58am
SMUTT
I meant to say in my earlier post that I had a similar problem when I bought the car.
I got 4 new tyres ... some old ones were ok but with winter on way I changed them all ... and the problem was solved.
.. Howard
Post #293347 16th Nov 2014 1:01am
Meerbusch
@ gpzjamie, I had this problem at a client´s Range Rover 2005, and after fitting one of this parts, the problem was solved...., best rgs, Uli
http://www.ebay.de/itm/ABS-SPURSTANGENKOPF...19f6b39b97 TDV8 4.4 from 2012, 278.000km like new + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #293420 16th Nov 2014 11:07am
With all due respect to the garage... If it was as simple as a track rod end! Then I'm sure that would have been diagnosed in a heartbeat Meerbusch...
The question the OP is asking is, "do steering racks fail often?" and you are quite right sir, the balljoints do fail on a regular basis... But to miss a balljoint & diagnose a replacement rack would be inexcusable...
Hence advice above, to exhaust all other options first Thumbs Up
Post #293426 16th Nov 2014 11:32am
verydisco
Does not seem like it is the rack, however, get in touch with kellybraysteering
I ordered mine from them and they offered a fantastic customer service + refurbed rack
email : <kellybraysteering>; l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #293743 17th Nov 2014 3:26pm
