Home > Maintenance & Mods (L322) > Changing brake pads on l322 TDV8 3.6
dysynni1
2009 Range Rover Vogue SE TDV8 Bonatti Grey
Just wanted to say many thanks to the forum members who have put up such detailed posts about changing the brake pads. Why I have not done this before myself, I do not know. This is very much a job you can do yourself and save hundreds of pounds to boot!
The first wheel took me about an hour, the second about ten minutes once I had figured out how to compress the pistons.
Looks as if changing the discs shouldn't be much of an issue either... Thumbs Up
Post #297734 8th Dec 2014 5:42pm
surprisingly easy isnt it... Wink
glad the job went well.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #297770 8th Dec 2014 8:23pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
is it just as easy on a 2010 4.4 tdv8?
cheers 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #297789 8th Dec 2014 9:18pm
should be if they are brembos.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #297793 8th Dec 2014 9:25pm
An extra central bolt/pin that the 4 pot does not have but much the same Thumbs Up
Post #297820 8th Dec 2014 11:12pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Yes it is a very easy job.
See link here.
I put suspension in off road setting then using the small rectangular jacking point I was able to get enough lift from my 4 tonne Jack to lift tyre off ground.
Use Jack stands as well.
Be careful with detaching the pad warning sensor. Wires are quite delicate so lift pad out of caliper with writes attached then gently slide out of pad slot.
http://www.fullfatrr.com/forum/topic28590.html
 '07 4.2 S/C
'13 X3M
Post #297830 8th Dec 2014 11:55pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i changed the rear pads and discs on mine this morning. interesting that the main dealer had said for the last two services that the rear pads needed doing, they still had 1/3rd material on them when i removed them!
Likewise they said the fronts needed looking at, well looking at yes, doing anything with no! scare mongery is good isint it! Cheers
James
Post #375715 4th Mar 2016 3:31pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
And that my friend is after 35 yrs in car trade we treat 99% of md's with utter contempt robbing lying barstewards Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #375723 4th Mar 2016 4:31pm
JST
looks that way Cheers
James
Post #375758 4th Mar 2016 7:53pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
looks nice and easy on the FFRR, not got to do mine yet but would consider an upgrade on the back maybe as already have bembro on the front.
Post #375769 4th Mar 2016 8:32pm
Scottyav
tbh just put a good groove and drilled disc set on the back and the standards are fine Thumbs Up _____________________________________________________
Post #375835 5th Mar 2016 12:28pm
