Home > Maintenance & Mods (L322) > Dustless pads for Brembo 2007 S/C |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34948 |
there is some conflicting info on these pads but obviously the redstuff work ok....there is also yellowstuff which fits the brembos so i wonder what they are like.. ... - .- -.
16th Nov 2014 12:17pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
My experience with the EBC pads were in my bobtail and were fitted when i purchased the car originally... I found (and am unsure which colour they were, although think Green) they were useless when cold and then very quickly faded and overheated... Probably the wrong colour fitted by an over exuberant previous owner...
16th Nov 2014 12:47pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Yellow stuff will take more heat without fade, but are a medium-high dust pad Early Greenstuff pads were utter I had a set physically catch fire, pedal gave no confidence etc. However they new range of Greenstuff pads appear to be fine. Run a set in wife's Freelander, and while they are not pushed hard, I have had no issues with them, and seem to work well as a like-for-like replacement |
16th Nov 2014 4:57pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
On the weekend I had my disc rotors delivered and is had the EBC Redstuff pads delivered in previous week so I sey about fitting them.
8th Dec 2014 11:42pm |
What brand of discs did you use? |
13th Dec 2014 10:57am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Interesting to see how you get on with those drilled and slotted discs . Not universally liked but the climate here may be kinder to them . 2008 MY Supercharged
13th Dec 2014 11:51am |
The discs were Britpart, so far they seem fine. A bit of noise from them under braking but barely perceptible.
13th Dec 2014 12:59pm |
Not Britpart discs, but drilled + grooved, after approx 15k miles...
13th Dec 2014 1:02pm |
