Home > Maintenance & Mods (L322) > What size spare wheel do people carry?
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Folks,
I bought a 2003 RR 4.4 V8 last month and it's had a face lift front and rear plus 20" alloys. The spare in the boot however is a 19" still.
I am wondering whether this would actually work if I got a puncture? It's quite heavy so does everyone carry a full size spare around these days or are there any other options? I didn't want to have it sat in my boot if I won't be able to use it in the event of a puncture.
Post #301009 26th Dec 2014 9:17pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
It's no different to cars carrying space savers.
I think you're limited to 50mph if you're using a smaller spare on the road.
I'd personally be looking for a full size to match the rest.
Post #301011 26th Dec 2014 9:32pm
scwilson
ok thanks, I'll have a hunt around for a 20" spare somewhere.
Post #301012 26th Dec 2014 9:36pm
As Mark said... But make sure you get the same style as the width/offset etc can change from wheel to wheel...
Post #301016 26th Dec 2014 9:53pm
scwilson
So there really is no point me carrying this 19" spare around at the moment? I assume running this with 3 20" alloys is not advisable?
Post #301343 28th Dec 2014 6:31pm
If you have standard recommended tyres fitted to your 20"s and 19"s you will have the same rolling circumference with both so in terms of "on the road" you should not expect any major issues driving on 1 x 19 and 3 x 20's, on your way to your local tyre stockist Smile - you won't want to be seen by other FFRR owners driving around on odd wheels/tyres now, would you? .
Post #301356 28th Dec 2014 6:49pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I have the original 18" spare from new and have used it twice in 8 years, all the time with 20" so I dont see it as an issue, just remember to have the different nuts with the spare Thumbs Up
Post #301357 28th Dec 2014 6:50pm
18" or 19" spares are not a problem if you run on 20" wheels, just regard it as a 'get you home' spare and you'll be ok... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #301361 28th Dec 2014 6:53pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
My spare is a smaller diameter wheel plus it uses the earlier type wheel nuts, so I have a pack of old spare wheel nuts should I have a puncture.
Post #301362 28th Dec 2014 7:03pm
I have same as Rosco, original 18" spare with a Goodyear, AFAIK never been used! Remember to check pressure occasionally, Last check by me, after @ 3 years was 7 psi Shocked .
Post #301394 28th Dec 2014 8:15pm
mzplcg
The 18 or 19 inch tyres have the appropriate profile to keep the same rolling radius so will work fine. However my own OCD mean's I must have 5 identical wheels and the tyres must also match.
Post #301423 28th Dec 2014 9:32pm
Rosco
mzplcg go for it Thumbs Up
Post #301426 28th Dec 2014 9:41pm
scwilson
Thanks mzplcg. That's good to know, if I do need to change one of my 20"s that the spare 19" will work ok until the other is fixed.
Post #301440 28th Dec 2014 10:09pm
mzplcg
You thinks that's bad. My wife is a Tamworth lass and if you visit our house and come in through the front door you can't leave through the back door. You have to leave via the door you came in. It's a Tamworth thing. Laughing
My tyre OCD make sense, to me at least although it does mean I have 2 almost new Nexens sat in the garage cos they didn't match the other 3 Continentals. Thumbs Up
Post #301484 28th Dec 2014 11:17pm
scwilson
Great advice Smile Thanks all. I have the 5 original nuts in a bag in the boot with the spare tyre.
Post #301506 29th Dec 2014 1:06am
