Home > Maintenance & Mods (L322) > Do the wing mirror puddle lights need error free leds ? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I had the same problem. Gave up in the end and put the originals back in.
6th Jan 2015 9:00pm |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Both mine went, no error. Put in LEDs and it's fine. No resistance error as far as I know. You remind me of a young me, not much younger mind, perhaps even a little older! |
6th Jan 2015 9:02pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
They don't work with LED's pal Not sure about can bus led's though...
6th Jan 2015 9:05pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
Hmm strange. Iv got error free bulbs coming tomorrow for the side lights. Il give them a try in the mirrors first. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Mine must be can bus error free then, that's not what it says on the tin. They do work tho.
6th Jan 2015 9:16pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
So, in the same vein - would I be able to put LED's in the rear number plate lights (I think they look much better)??
6th Jan 2015 11:21pm |
No, that worked ok for me. It was just the wing mirror lights for some reason Got - 2017 SDV8 Autobiography in Loire Blue
6th Jan 2015 11:35pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
CEEGEE, the number plate lamps will have to be error free, but they are as cheap as chips, I got 5 for £2.50 from ping pong via fleabay Mind you they did take nearly a month to arrive, probably not the best way to go if your impatient , or in desperate need to join the rest of us
7th Jan 2015 1:16am |
Yep, had a look last night - looks as though I can get UK supplied for about a fiver |
7th Jan 2015 8:39am |
Error free bulbs came today for the side lights. Quickly tested them in the mirrors and they work fine. So I will be ordering a few more and think I will get the number plate ones as well.... addicted
7th Jan 2015 12:52pm |
also can anyone help me on how to remove the covers from the main front and rear interior lights
7th Jan 2015 3:52pm |
NO DONT prise them off Mark... Open the glasses holder in the front and you will see 2 8mm headed bolts up inside, remove them and then the whole console will pull down from the roof... The front & rear lights are held in place with two crosshead screws from the rear
7th Jan 2015 6:18pm |
Ahh. Thanks Craig. I knew there had to be something holding it.
7th Jan 2015 6:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34934 |
i've just put 6000k xenon bulbs in mine, much better..
7th Jan 2015 6:53pm |
