Home > Off Topic - Other Cars > Freelander problem assistance required |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Earlier this week I had to assist one of my friends as her Freelander would not start.
23rd Jan 2015 11:00pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Camshaft sensor. Land Rover Addict
23rd Jan 2015 11:06pm |
Thanks. maybe a daft question, but why does leaving it unlocked affect the camshaft sensor? 56 TDV8 Vogue SE
23rd Jan 2015 11:37pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Loose terminal on the starter motor is the most likely culprit
24th Jan 2015 9:08am |
Fixed, spot on Mikey was a loose connection on the solenoid. 56 TDV8 Vogue SE
25th Jan 2015 6:41pm |
25th Jan 2015 7:33pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
Good its sorted another one I had on my p38 was the cable from the battery to the started had internal corrosion so giving it a wiggle and it started for a while replaced the cables never had it comer back might be worth a look |
25th Jan 2015 8:20pm |
