Home > Maintenance & Mods (L322) > WARNING change your diff oil!!!
Page 8 of 10 <12345678910>
Arkle
n1cktdv8 wrote:
Mine done last week during Transmission service. All good on mine but garage commented the same; people forget them all to easily.
Which garage do you use for servicing, Nick?
Post #313984 20th Feb 2015 9:54pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
pld118 wrote:
Agreed Emirates. £6 for 2 is not worth risking it Thumbs Up
Its a piece of mind knowing that its not all on the floor back up the road.
I am not sure if stealers change this when they do a oil change ? - I presume they just plug the hole with the old one.
I like to know my holes filled Big Cry - say no more
Post #313991 20th Feb 2015 10:28pm
pld118
Our recent service invoice says they put a new oil plug in for the engine oil change Whistle
Post #313994 20th Feb 2015 10:33pm
EmiratesA380
Quote: " Our recent service invoice says they put a new oil plug in for the engine oil change "
Thats a MUST - never use the old plug when changing the Engine oil as the rubber seal has been stressed.
Its the Sump plugs that - are just as important - that's where all thous lovely 700Nm Torque end up Bow down
I tried explaining this to my misses - but its goes over her head
Post #313995 20th Feb 2015 10:36pm
EmiratesA380
Hears a question to all
Why - when you have a massive 700Nm Torque being produced by that lovely V8
do you have a Front Diff that only holds 0.75 liters
and the rear
Holds a massive 1.14 liters
Surly the back diffs having a laugh - the front diff is having a hell of a work out ?
Post #313996 20th Feb 2015 10:45pm
pld118
No idea but we had 4 tyres fitted at the same time and the rears are wearing quicker.
Post #313998 20th Feb 2015 11:11pm
and the rear
Didn't some one say they were splash lubricated ? 2008 MY Supercharged
Post #314021 21st Feb 2015 12:56am
EmiratesA380
Hi Axle
Interesting thought - and thanks for letting me know.
Is this any help?
FRONT DIFF
REAR DIFF
again it might help FFRR owners - Knowledge is a good thing Thumbs Up
Post #314042 21st Feb 2015 8:38am
axle wrote:
Doing mine today so after a long search found that in Western Australia no one will stock Castrol BOT 720 apart from LR so I go down to the only dealer in the state , $100 Shocked and they have just one litre Evil or Very Mad but I have literally no choice and after some searching we find that Jaguar use it in their final drives as well , Jaguar labeled BOT 720 is $171 Shocked Shocked
So that will put some perspective on it when you next feel like you main dealer in the UK is ripping you off a bit .
edit
All done now , nice easy job with a bit of heat around the filler plug and out it came , oil was quite glittery but not a bad colour and after I finished I checked with the IID and I only have 57% clutch left so I might have to stop wanging it out of 90 degree junctions Embarassed and for the drain plug it is a 3/8 socket drive not 8mm .
I said I would keep an eye on this and a couple of months later I have 54% travel left , something is going away it seems . 2008 MY Supercharged
Post #327011 10th May 2015 11:48am
pld118
4.4TDV8 Fluids
Well, I've placed an order with Dan @ Duckworths so that I can change the following, as the 4.4TDV8 is touching 30k miles:
1. Front Diff Oil - Castrol SAF XO 75W/90 (0.75L to refill)
2. Rear Diff Oil (electronic rear diff) - SAF Carbon Mod Plus (1.5L to refill)
3. Transfer Case Fluid - Shell TF0753 (1.5L to refill)
4. And new drain plugs for the front and rear Diffs, just in case!
Point of note if if helps anyone - the above required fluids are the same specs as were required for the 4.2 SC.
Post #354761 31st Oct 2015 7:42am
GraemeS
Karcraft in Sydney stock the oil but can be out at and given time, such as when I wanted some for my D4 although their new stock arrived in time.
At this stage I don't know whether I'll retrofit/convert an e-diff to the RRV but the oil for the open diff is available locally from any Castrol supplier.
Post #354781 31st Oct 2015 11:30am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
axle wrote:
Put you IID tool to live values and scroll to RDTC Rear Diff and scroll down , it's actually clutch travel left not wear so in fact it might mean something slightly different .
I tried to find this today, but it's not listed in my live values. Is it vehicle specific or have you got a different version of iid to me?
Post #354889 1st Nov 2015 7:22pm
The clutch travel remaining should be there but I see your's is a 2006 so I assume its a pre facelift supercharged , don't know if that means anything . I have have an ordinary and non bluetooth iiD and they both showed clutch travel . Since changing my oil clutch travel available has stabilised at 54% so old damaged/contaminated oil is clearly very damaging . 2008 MY Supercharged
Post #354957 2nd Nov 2015 2:35am
pld118
Changed the rear Diff Oil this afternoon and re torqued the drain plug at 54nm and the fill plug 34nm.
Manual says refill is 1.5L. From the old oil, only 1.3L drained out. Only managed to get 1.4L new oil back in because at that point, it started overflowing slightly from the fill hole, which I find a bit puzzling.
Bit concerned too now that when reading the front diff refill manual it says if it shows signs of overflow, drain off and do it again. Although no such advice is given on the rear diff refill section. Should I be concerned enough to drain it and do again?
ps. old oil wasn't too bad a colour although there were small metal flake particles in the old oil.
Post #355889 8th Nov 2015 6:53pm
Zirconblue
There are two figures in the manual (at least in the older ones there are)
One for a fill from dry (ie a new diff) and one for a drain and refill.
Draining and refilling doesn't get all of it out.
So the 1.5l is probably fill from dry.
Post #355916 8th Nov 2015 10:30pm
