Home > Technical (L322) > Dreaded Flat Battery |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
The battery always seems to settle at 12.2v. Could that be the battery that is faulty then.. I've just had it out and it started 3 times no problem. |
22nd Feb 2015 4:59pm |
Thanks, it's looking more and more likely that a new battery is needed even though this one is less than 12 months old. Before I bought it Geoff had done the alternator, fsr etc.etc. |
22nd Feb 2015 5:28pm |
Did you replace the battery when you replaced the alternator? If the Alternator was spiking then it could have knackered the battery in which case it won't hold charge properly.
22nd Feb 2015 5:42pm |
I think everything was done at the same time while he was trying to sort the flat battery problem.
22nd Feb 2015 5:52pm |
I ran the recon cycle overnight and when I checked it this morning while still connected it was showing 13.5v. When I unlocked that dropped to 12.2v.
23rd Feb 2015 10:19am |
Based on the readings above I have either got a drain or the battery can't hold full power
28th Feb 2015 11:59am |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 452 |
Fish: Did you get a new battery in the end, and if so did it cure your problems?
6th Mar 2015 12:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34947 |
those voltage figures sound ok Steve.. ... - .- -.
6th Mar 2015 12:30pm |
Thanks, Stan.
6th Mar 2015 12:43pm |
I've not sorted mine yet, I've been monitoring it this week. After a few days of short journeys it seemed to settle at 12.2v but this morning was actually 12.1v. I have had a good motorway run today so will check it again tomorrow.
6th Mar 2015 3:31pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
If you've had a decent run on the motorway today your battery should now be reading 12.8-12.9V or even 13V due to surface charge.
6th Mar 2015 5:57pm |
Thanks, nicedayforit (that’s a mouthful! (And do you really look like your Avatar?!!!)
6th Mar 2015 6:26pm |
Oh, sorry, that last remark by nicedayforit was maybe directed at Fish?
6th Mar 2015 6:27pm |
@bebechoon
6th Mar 2015 6:45pm |
