Home > Technical (L322) > fbh
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Cam-Tech-Craig wrote:
ajac8 wrote:
Just how warm is the inside supposed to get? When I have run mine for the max 30 mins the inside is only really just 'off cold' - You can tell its been warmed up but only just.. I appreciate the ambient temp will have a lot to do with it but does anyones cabin get 'toastie' warm so to speak? Is my FBH short changing me?
(also flashing green light every three seconds Thumbs Up )
I hate to state the obvious sir but, what are your heater controls set to? If they are not up high, the cabin won't warm that much... Thumbs Up
The manual does not refer to the need for temp settings, on the contrary to my mind it infers that the ambient temp dictates whether the fhb activates or whether cool air is circulated. I'll give its go tho. Thanks Craig.
Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #302629 4th Jan 2015 11:36am
TheTowers
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Alistair wrote:
For basic troubleshooting, try turning it on manually from the home screen in the car - that will help narrow it down to whether the FBH is working, then you can start worrying about the remote.
My fbh seems to work on timer and for engine running warm up, but the 'manual' option is greyed out. Does that suggest it doesn't have the remote kit? The car didn't come with a fob.
Post #302689 4th Jan 2015 5:48pm
JAYBOY
It may have a receiver and the previous owner may have lost the remote.
On my 2008 car the receiver was in the back rear right compartment. Someone will tell you what id written on it but i think it says siemens. I'm not sure on a 2010 model and it to dark for me to check mine now.
Mine is back in to Landrover tomorrow as mine is still not working Big Cry Big Cry 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #302693 4th Jan 2015 6:17pm
Weegie
If you pm Dan at Duckworths he can get you the build sheet for your vehicle which will show if it originally had FBH and Remote. He will probably want your email address. John
GAP iiD BT
Post #302704 4th Jan 2015 7:44pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
mine does not get toasty
de-frosts ok and lifts the temp ,but deffentley not toasty
ran it with the blower fuse removed for 10 mins then put the fuse back in, only then did it get toasty
so i think blower fans run to fast to heat the water up enough on a 30 min cycle
wonder if fan speeds differ on later models
Post #302705 4th Jan 2015 7:48pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Cowman
I just looked for Mikes email and noticed I sent it to you 13th Feb.
If you can't find it I will resend Thumbs Up
Post #302706 4th Jan 2015 7:49pm
Andy
Mine isn't toasty either. It's not cold and the windows defrost. When I get in and switch in the heater, it blows warm(ish) air. Coming off a night shift, it's better than getting into a freezing car!
Can I fit a T90 receiver to my 2002 model? It's a different plug to a T60 so I'd need to fit a new plug to the loom but where to get one from? Is there any additional wiring to a T90?
Post #303040 6th Jan 2015 9:08am
ironhorse
dont know if this reply is to late but i would not bother with the remote
put a GSM dialer on it and you can phone it frrom anaywhere in the world to switch it on, your not limited to 500m away
drops the call so no call cost involved
£60-70 depends on what make you buy and PAG sim card with £5 credit and jobs a good one
the one i use is Advent Controls Alpha GSM Relay Board
also use this on my electric gates
just make sure the GSM dialer has a timed relay (so you can set the heater run time)
first page of instructions=
The Advent Controls Alpha GSM Relay Board has been primarily designed for security applications
although can be used as a general purpose call/SMS activated relay. The board also
features an optically-isolated DC input which can be used to trigger dialling and/or sending of
a customisable Short Message Service (SMS) alert message to up to 512 numbers.
The relay can be activated by a call or SMS text from up to 512 stored telephone numbers or
can be configured to activate when receiving a call from any number. By default the call will
not be answered and hence costs the caller nothing. However, the system can also be set to
reject the call or connect a call when either the input is open or closed (or both). This allows
the input status to be determined even when the SIM card does not have credit for SMS text
messages.
Setup and operation is performed by simple SMS text messages including adding and removing
user telephone numbers. A complete list of accepted telephone numbers can be viewed
via SMS text message. The memory can also be scanned to see if it contains an individual
number and the result is displayed by the on-board LED and (if enabled—see 2.10 TEXTRES) by
SMS text message.
The output relay has both Normally Open (NO) and Normally Closed (NC) with Common
(COM) connections. The action of the relay can be a single timed actuation from either 1s to
999s or 1 to 999 minutes or the relay can be set to toggle between calls.
1.2 Technical Specification
Power Supply 12-24VDC 500mA Max. (10-15mA idle)
Relay Output 5A Max. CATII 220VAC
SIM 1.8/3.6V
Compliant with GSM Phase 2/2+ Class 4 (2W @850/900 MHz)
Class 1 (1W @1800/1900 MHz)
Antenna 50M U.FL
Post #309001 29th Jan 2015 2:31pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Way above my capabilities but a great mod Thumbs Up
Post #315444 28th Feb 2015 4:15pm
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
I'm also in the 'FBH not working' club Rolling Eyes
I don't have an IID tool and having read the many posts on here about the FBH, I sent the PCB off to French Mike. He found a fault Smile fixed it Very Happy and having reinstalled it..... it made no difference Sad The system is completely unresponsive other than the flashing light by the screen.
Does anyone around the South West / Bristol area have the appropriate kit and know-how to tell me what faults it is generating....? Question
Cheers, Jon.
Post #315479 28th Feb 2015 10:57pm
J evro
Ouch!!!
Did you do the reset procedure ( ie 3 fails to start and reset system ) ?
Post #315487 1st Mar 2015 1:37am
jon3929
I have tried pulling fuse 59, but it makes no difference Confused The light by screen still flashes but there is no activity at all.
I know there are various tests you can do on each of the FBH systems but of course the battery needs to be out of the way, so I've concluded my best next step is to get the codes read.
Cheers, Jon.
Post #315496 1st Mar 2015 8:26am
