Home > Technical (L322) > Clunky changedown after full service (inc gearbox service). |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Yours is the 6sp sir and yes it is critical the correct grade is used!!! |
6th Mar 2015 10:19pm |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 |
Many thanks, Craig, |
6th Mar 2015 10:51pm |
Ok. I have decided to take my car to Guy Salmon at Knutsford to have the ATF changed.
11th Mar 2015 6:50pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I'm afraid dropping the pan and changing 9 litres of oil in your gear box will not do , you would now have a situation where you have two different oils mixing in the gear box . The gear box will now have to be flushed by megaflushing at a specialist and refilled with ZF lifeguard 6 , it won't be cheep because Lifeguard 6 is not cheep but this is now you only course of action after the incompetence of the first garage servicing your gear box with out bothering to find out how .
12th Mar 2015 2:45am |
Thanks, Axle.
12th Mar 2015 3:05am |
Put a request out on here for recommended/trusted companies in your area used by forum members on here |
12th Mar 2015 10:11am |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
I can write with some authority on this as I have the T Shirt. A so called "LR Specialist" filled my auto box with industrial bus / coach ATF the uknown here is you do not know the specification of the ATF that has been put into your gearbox. You also do not know the exact specification of LifeGuard 6 ATF so it is impossible to say that you have the wrong ATF.
12th Mar 2015 11:09am |
Good thinking Batperson. |
12th Mar 2015 3:12pm |
Very interesting stuff, Skot. PM sent. |
12th Mar 2015 3:13pm |
I'm not a million miles away from RRPhil. I wonder if he would interested in changing my ATF or recommending a man that can? |
12th Mar 2015 11:03pm |
Okay, here's a plot thickener if ever there was one.
5th May 2015 11:16pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7941 |
hell... your not having a lot of luck are you...
5th May 2015 11:30pm |
Thanks, Pete.
5th May 2015 11:38pm |
I used to feel like that about cars.... try and change your point of view...
5th May 2015 11:44pm |
