Home > Wheels & Tyres > TPM system.........again |
The antenna for the spare tyre (at least in the 2006 MY I have) is fitted in the trunk area so it picks up the signal of the spare tyre, i.e. it checks the spare tyre pressure. It even gives a separate alarm when the spare tyre pressure is too low (happened to me several times). On my 2006 MY SC the TPMS worked fine so I never touched it. On the 5.0 SC I don't know if it is activated, need to check when I get to the car next with my Faultmate.
11th Mar 2015 1:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34933 |
had the same problem with the intermittent 'check all tyre pressures' and like yours my pressures were spot on...i disabled my tpms with the iidtool and had rubber vales fitted..i know this doesnt help your problem but it made me feel better.. ... - .- -.
11th Mar 2015 1:55pm |
stuck Member Since: 23 Jan 2015 Location: Lancashire Posts: 53 |
Which ECU do you attack to check the status of the TPM? Diesel - Just Say No!
11th Mar 2015 8:42pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Should check your tyres every week anyway...not just the pressures....and the spare for that matter, just saying If it dont work.......burn it!
11th Mar 2015 8:50pm |
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 |
Gets curiouser and curiouser. Long run at 70 mph on motorway and light goes off and stayed off for 40 miles. Start pootling around the lanes at lower speed and the light keeps coming on / off. |
12th Mar 2015 5:52pm |
there are little antennas somewhere in each wheel arch that pick up the tpms signal, maybe one of those is loose and when you swing the FF round corners the signal is intermittently lost.. ... - .- -.
12th Mar 2015 6:51pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7782 |
I had a similar intermittent problem for ages - good money after bad - replaced all the valves then a couple of the sensors and it was still happening.
12th Mar 2015 8:08pm |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
This isn't going to help mush but I have the same problem - seems to be worse as the weather warms up for some reason. I have replaced the antenna in the spare wheel well to no avail but gave up at that point as the garage seemed intent on solving it by replacing one item at a time at my cost.
12th Mar 2015 9:43pm |
Sounds familiar
12th Mar 2015 10:12pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Will only fail an MOT on a post 2012 car. The working TPMS requirement was not retrospective 56 TDV8 Vogue SE
12th Mar 2015 11:17pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
My TPMS worked perfectly, then I swapped my alloys for SC ones with new tyres and TPMS valves all round and ever since its 60:40 working/broken
13th Mar 2015 12:36am |
Swing it round corners? We serenely sail! |
13th Mar 2015 12:46pm |
Can you let me know where the antenna is in the spare wheel well? |
13th Mar 2015 12:47pm |
