Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7909 |
Well it's finally happened, I bought my FF in the knowledge that it probably required a gearbox rebuild, it has a hard 1st to 2nd change and slurs the 2nd to 3rd change at anything more than a gentle throttle.... every now and again it would "bong" and put on the Trans Failsafe and lock in 4th gear. I have changed the oil and filter twice as it had the wrong oil in it (red) and also changed the rad and thermostat for the oil cooler as it ran hot as well, it ran a bit cooler but still hotter than it should...
17th Mar 2015 7:24pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
Re your final question this might give you a guide to a gearbox http://www.owzat-cricket.co.uk/acatalog/Ab..._Box_.html
17th Mar 2015 7:31pm |
Prepros123 Member Since: 28 Sep 2014 Location: Cornwall Posts: 35 |
I must say good luck for having a go. I have rebuilt manual boxes but don't think I would try on a auto.
17th Mar 2015 11:23pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 912 |
I’m here for you Pete . There’s really nothing to it, you’ll be amazed by how simple it is - and if it all goes t*ts up you can always just shovel all the parts into a crate, send it over to sunny Blackburn and I’ll sort it out for you.
18th Mar 2015 12:27am |
Wow... thanks chaps, nice to know I'm not alone, Phil, having seen those pics and knowing what I'm like at loosing that all important "wooopy cam flange" I will probably take you up on that....
18th Mar 2015 12:40am |
RRPhil
18th Mar 2015 5:41pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 586 |
you are a brave man pete |
18th Mar 2015 6:55pm |
I sent Phil a few questions by PM but as he pointed out they are better on this thread to help out others in the future, so here they are.... Good call Phil...
18th Mar 2015 9:35pm |
Sorry, that link for the ZF official part suppliers doesn't seem to be working. Hopefully this one does :
18th Mar 2015 10:48pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Good luck pete. I really admire you having a go.
18th Mar 2015 11:38pm |
By far the worst part is getting the transmission out of the car and then back in again. Rebuilding the transmission is the easy bit. I’ve attached the later instructions which leave out having to remove the viscous fan and rear propshaft (shortening the time from 5.4 hours to 4.7 hours! – that’s to remove and install)
19th Mar 2015 1:19pm |
Cheers Phil, don't have a problem taking it out, I have the use of a ramp so it's not too bad, no rush so just take it steady.... did the last one a few years back on a classic on my mates drive in November, main front seal on the autobox went so we changed that... wasn't too much fun but hey-ho....
19th Mar 2015 6:00pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
@Haylands, If I was doing the rebuild I would err on the safe side and get the TC refurbed/rebuilt at least. You're going to end up with a great gearbox and for the sake of £250-00 odd for the TC, it would be well worth the while getting it done. My train of thought would be that at least you know the TC won't fail just after you've got the gearbox up and running again.
19th Mar 2015 9:13pm |
Usually you would get your own torque converter re-manufactured (they usually turn then around in just a couple of days). There’s nothing much to see from the outside as it’s a welded assembly so they have to turn off the weld to separate the two halves and then weld it back together again when the work is finished (it’s then pressure tested and balanced). The lock-up clutch in the 5HP24 TC is notorious for only lasting just over 100k miles and, as the transmission would have to come out again to replace it, I would suggest - if funds will stretch to it - that you get it re-manufactured while it’s out.
19th Mar 2015 9:18pm |
