Home > Maintenance & Mods (L322) > Fitting new battery.
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Will i be able to fit a new battery ok?. Looks a tight squeeze between bonnet and battery home! Thanks in advance.
Post #32209 18th Oct 2010 11:19am
just done one and yes it is a tight squeeze but easily diy...make sure you put the bonnet in service mode and have a stool handy to stand on.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #32210 18th Oct 2010 11:25am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
how do you put the bonnet into "service mode" scarey? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32213 18th Oct 2010 11:45am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Tip: Its easier to do with 2 people.
On top of the gas struts there is a small metal retaining clip that hold the head onto the ball joint. Use a small screw driver to remove it on both sides. Then whilst supporting the bonnet, pop the gas strut off of the bonnet and push upward until the hood is vertical. Now look at the support arms for the bonnet and locate the flat clip that looks like a spare bit of metal. Rotate this and clip it over the pin. This locks the bonnet in the upright position (service mode).
To reset to normal reverse the procedure. The metal clips that secure the gas struts in place are a little fiddly to replace but if you look closely there is a groove to slide them down on top of the head. I usually end up using a small hammer to gently tap them back into place. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #32214 18th Oct 2010 12:04pm
open bonnet, unclip the two bonnet supports at the bottom, these can sometimes be done by hand...lift the bonnet to vertical and on each side there is a sliding bit of metal that clips onto the support mechanism to keep the bonnet upright...
edit...steve beat me to it.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #32215 18th Oct 2010 12:05pm
Tim in Scotland
Thanks guys, I'm sure there are others who were wondering too! Maybe it should have a "sticky" at the maintenance and modification section? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #32224 18th Oct 2010 1:20pm
td6 vogue
Yeap thats what i wondered, if the bonnet could open up more. Thanks for the info. Thumbs Up
Post #32226 18th Oct 2010 1:28pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
http://www.youtube.com/user/elpeede#p/a/u/2/8Hq6Ox86xho
1 minute 50 seconds in to the video. (Part 3 if it doesn't come up automatically) 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #32232 18th Oct 2010 1:54pm
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Someone step in if I'm wrong but I'm sure I was told that the negative lead has an explosive charge on it to disconnect the electrics in case of impact. If not, I'm possibly confusing it with something else but if so, be ****** careful!! Shocked 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #32330 18th Oct 2010 10:46pm
Link to Battery Disconnection howto
http://www.fullfatrr.com/forum/topic2102.html?highlight=battery
JW911 - its on the positive (red) side .
Post #32333 18th Oct 2010 10:51pm
JW911
Thanks for that. Mind your fingers. 2012 4.4 TDV8 Westminster
Post #32364 19th Oct 2010 8:48am
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
Thanks guys,after reading this Topic i pluked up courage and fitted my new Battery this morning.
Everything was totally as described,i was by myself but was easy to put bonnet in service mode. After turning of ignition i waited ten minutes Then removed the neg terminal. Waited a further 20 mins then got stuck into the pyrotechnic poss. Easy,new battery on,bonnet resorted,start car and toun steerin full left then full right.Job done. Only memory loss was on existing trip. no problem, so thank you guys,i am indebted. Rolling with laughter
Post #42879 20th Dec 2010 5:37pm
result.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #42883 20th Dec 2010 5:44pm
dan_uk_1984
You may find your sunroof has lost its "home position" next time you use it. Hold the close direction for 15 seconds to re-initialise it.
Dan
Post #42898 20th Dec 2010 7:33pm
Dan
God how I love my basic SE....no sunroof so one item less to worry about Thumbs Up
Post #42915 20th Dec 2010 8:33pm
