Home > In Car Electronics (L322) > Resler Interface
thatgirl101
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Resler Interface
Hi all,
I'm trying to install a Resler interface into my 2003 V8 Vogue. Am I right in thinking that all I need to do is find the right cables in a loom (i.e. Ibus, ground, live), pull out the relevant pins, push in the corresponding cable from the interface and push the pin back in?
I have an accessible wiring loom connected to my bluetooth module - I was thinking of just wiring it in to that - would that work?
Thanks v much.
Post #324542 26th Apr 2015 5:32pm
mjdronfield
Not done it myself, I use the OBD 2 connection under the dash for Navcoder, that can also use a resler interface.
I believe you can wire it as you describe.
It just piggy backs on the loom.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #324545 26th Apr 2015 5:37pm
miggit
The I-bus is commoned up behind the glovebox just above the fuses, so in theory you should be able to piggy back on to the I-bus at any module on the system. But as Mark says I also use an OBD II lead to connect the Navcoder, after a wise man put me on to the lead!
http://www.ebay.co.uk/itm/BMW-Diagnostics-...735659568? Yesterday I couldn't spell Engineer... Today I are one!
Post #324576 26th Apr 2015 8:14pm
The old fashioned way:
And see
http://www.fullfatrr.com/forum/topic8786.html .
Post #324586 26th Apr 2015 10:04pm
thatgirl101
I bought one of those OBII cables but never managed to get it to work with NavCoder.
Will try wiring in the Resler interface this week, thanks for the replies.
Post #324613 27th Apr 2015 9:30am
miggit
Did you load the drivers that came with the lead? and then set it to com 1 ? Mine was less than cooperative, but in the end it gave in and installed its' self. Only the car speaks serial (RS232) the the computer has progressed to usb so with out the drivers (translator) they aint gonna talk Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #324722 27th Apr 2015 10:37pm
thatgirl101
I'll try the OBII cable again tonight - unfortunately, though, I've lost the driver CD. Does anyone know where I can download them from?
Post #324742 28th Apr 2015 8:48am
