Home > In Car Electronics (L322) > Resler Interface |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7640 |
Not done it myself, I use the OBD 2 connection under the dash for Navcoder, that can also use a resler interface.
26th Apr 2015 5:37pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The I-bus is commoned up behind the glovebox just above the fuses, so in theory you should be able to piggy back on to the I-bus at any module on the system. But as Mark says I also use an OBD II lead to connect the Navcoder, after a wise man put me on to the lead!
26th Apr 2015 8:14pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
The old fashioned way:
26th Apr 2015 10:04pm |
thatgirl101 Member Since: 28 Feb 2014 Location: London Posts: 45 |
I bought one of those OBII cables but never managed to get it to work with NavCoder.
27th Apr 2015 9:30am |
Did you load the drivers that came with the lead? and then set it to com 1 ? Mine was less than cooperative, but in the end it gave in and installed its' self. Only the car speaks serial (RS232) the the computer has progressed to usb so with out the drivers (translator) they aint gonna talk Yesterday I couldn't spell Engineer... Today I are one!
27th Apr 2015 10:37pm |
I'll try the OBII cable again tonight - unfortunately, though, I've lost the driver CD. Does anyone know where I can download them from? |
28th Apr 2015 8:48am |
