Home > Wheels & Tyres > TPM system.........again |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
@birdbrian,
13th Mar 2015 12:56pm |
no, you will have to fit on FF and drive for at least 15 minutes......saying that , LR diagnostics can re-programme the sensor while its in the spare, but that will cost.. ... - .- -.
13th Mar 2015 1:19pm |
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 |
Cheers Stan.
13th Mar 2015 1:43pm |
We seemed to have solved the problem. Local indie found spare wheel sensor and / or aerial giving error. From Stans post and other research I'd done I dediced it could be the TPM module in the boot as that also acts as the aerial for the boot. We fitted a borrowed module and problem went away. Now nearly £100 lighter after buying a new one. Fingers crossed........ |
13th Mar 2015 4:06pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7785 |
Are you sure ? I agree that TPMS isn't a requirement on a pre-2012 car. However, I thought if it was fitted, then it has to work - any warning lights are an MOT fail for all cars. |
13th Mar 2015 8:58pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Think it is because it is not a testable item, so can't failed
13th Mar 2015 11:09pm |
I thought that any options fitted had to work - including towing sockets and the like.
That's what I was told by my MOT tester - but he could have been wrong..... |
14th Mar 2015 1:06am |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
Sorry I didn't get back to you on the location Birdbrain but see Stan's got there now - all done by the garage anyway so I don't know!
14th Mar 2015 9:28am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
I seriously wouldn't fork out any more money on new valves.
14th Mar 2015 10:53am |
elmer Member Since: 24 Mar 2013 Location: Spain Posts: 17 |
What iidtool did you bougth?could you cancel the tpms warnings? Thany you |
3rd May 2015 11:07pm |
I had the bluetooth one, but I think they can all disable the TMPS
3rd May 2015 11:31pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I fitted a TPMS system to my ffrr, I'm really happy with it , but it's not a L/R product Mine has a display that constantly shows the Tyre pressure and the temperature, and goes nuts and starts flashing and bleeping if the pressures drop or the tyre gets too hot (getting ready to go pop ). It does have the in wheel monitors, as opposed to the cap type, which I was told can't handle pressures over 30 psi. So they would have been on good for me as the rears are run at 45 psi ( needs to be for towing very heavy trailers, that have large tanks with liquid slopping about in them ).
4th May 2015 9:40pm |
Hello,I'm waiting for the final confirmation that I can cancel the TPMS warnings with the IID BT Tool number DA6412 (britpart) to buy in England and I send him to Spain.
4th May 2015 11:59pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
YES 2008 MY Supercharged
5th May 2015 1:46am |
