Home > Maintenance & Mods (L322) > 2010/2012 facelift conversion - my step by step guide |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Glad you have found it useful! If you need any help you can contact me directly Matt |
6th May 2015 11:48pm |
The entertainment project is one of those that has become a huge monster, i built the whole system based on a third party base software then decided that it was too limited to add new features so i decided to scrap it and rebuild it from scratch writing my own code which where all the delay has come from. I am also in the process of completely rebuilding my website and expanding its content massively which is also taking a lot of my time up. I will post any updates and developments on the project and website on here and on my site. Matt |
6th May 2015 11:52pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
Brilliant write up pal, car looks top dollar now Dan
7th May 2015 5:37am |
Sharkey Member Since: 02 Jun 2015 Location: Devon Posts: 1 |
Hi. Great job in detailing the conversion. I've nearly finished mine and am having a few minor probs with the front lights. I tried the led conversion boxes without success (the backs worked a treat) both myself and the chap who provided them can't work out why they won't stop the fast flash and they make no difference to the side lights as they worked anyway! So I've ended up fitting Powerfull's 22 Ohm resistors and they fix the flash issue. I still have the "check front light" warning on the dash, everything works as it should just wondering if anyone has a work round or experienced the same issue... Thanks in advance! 2003 Vogue TD6 converted to black 2012 set up |
2nd Jun 2015 8:33pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6672 |
I'm thinking about embarking on my CEC before winter really kicks in. I've got all the bits but the one thing I can't seem to find is a wiring diagram for MY06 onward headlights.
24th Sep 2015 6:46am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
If yours is a VSE Alan? It will have the correct plugs! Just need pinning out and wiring moving around sir |
24th Sep 2015 7:08am |
It is Craig and I know I have the correct plugs, but I don't have the details of the rewiring I'll need to do. All the stuff I've read is only relevant to 2003-06 cars with the old style headlights.
24th Sep 2015 7:59am |
Remind me when I get home... I'll have a look and see if I have anything... Also, check with NickTDV8 as he did his, which is the same as yours... He may have something I sent him that he could send on Alan... |
24th Sep 2015 8:28am |
Thanks Craig, much appreciated. Got - 2017 SDV8 Autobiography in Loire Blue
24th Sep 2015 10:16am |
Alun1976 Member Since: 12 Oct 2015 Location: merseyside Posts: 10 |
Great write-up. This will help me a lot with my conversion. Thanks
12th Oct 2015 1:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
have a look on microcat for the part numbers , link in the wiki.. ... - .- -.
12th Oct 2015 10:45am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
Inspiring project |
12th Oct 2015 7:41pm |
Not much point in getting AFS headlights, as they won't work with adaptive headlight equipped cars <2010 AFAIK Got - 2017 SDV8 Autobiography in Loire Blue
12th Oct 2015 7:46pm |
Grest write up Matt. This helped me a lot as I started my facelift conversion today. One thing I'd like clarifying that doesn't seem to have been mentioned before is, what did you do with your air intake pipe that runs from the air filter to the off side front wing? I've had to remove this duct as the new headlight fouled it. Is there a different air duct needed, one that provides more clearance for the drivers side headlight.
18th Oct 2015 7:26pm |
