Home > Technical (L322) > Air Con System Pressure, What should it be? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
I saw this a few months ago hope it helps, I will check mine tomorrow and report back but the at the beginning of the year im sure iid tool showed it at 12 bar hence me checking too.
12th Jun 2015 9:40pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Cheers Welshdragon, I can see what he's saying on the link about weight versus pressure, but at 5 Bar pressure that's 72.5 psi which is quite a high value. If there was a leak on the system, I'd expect a figure much lower, remember that car tyres are pumped up to between 2 and 3 bar maximum. Refrigerant is a gas after all, it only turns to a liquid when under pressure.
12th Jun 2015 11:20pm |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
5 bar should kick in the compressor. Thats standing at about 20.0oc ambient.
13th Jun 2015 11:15am |
I checked the pressure and my ff is showing between 14.168 to 16. 335 bar on tick over if that helps. If it dont work.......burn it!
13th Jun 2015 8:38pm |
Cheers for the replies guys, looks like I may have a slow leak somewhere in the system. Will have to get it in to an air con specialist, rather than just get a re-gas at Halfords. Hey ho, that's life. |
15th Jun 2015 11:33am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
They insert a colourful die into the system and you will be able to see where the leak is.
17th Jun 2015 2:04pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2929 |
I'm having problems with my air con
17th Jun 2015 6:17pm |
