Home > Technical (L322) > neg nut of shocky tower |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7792 |
I have no idea what a 'shocks tower' is
8th Aug 2015 9:34am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
If LR deemed a nut necessary it should still be there.
8th Aug 2015 9:46am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
If you can't find it then just replace with an equivalent standard nut. You need a nut on there because from memory it secures the suspension leg (it might be an extra point though), you don't necessarily need a neg post terminal which is just there to aid jump starting. |
8th Aug 2015 9:57am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Sounded like a new Harry Potter book when I first read it Got - 2017 SDV8 Autobiography in Loire Blue
8th Aug 2015 10:04am |
Looking at a photo it's an extra point purely for the negative which is not structural, you don't necessarily need it as it's only there for jump starting. Whack a couple of ordinary nuts on there.
8th Aug 2015 10:12am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
Thanks weejock. |
8th Aug 2015 10:14am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
if it comes to it i doubt the original nut will cost a lot to buy from a dealer. |
8th Aug 2015 10:32am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
you obviously don't know Land Rover Australia then . 2008 MY Supercharged
8th Aug 2015 10:37am |
I know Land-Rover UK, while they do rip you off on most things, small fixings like nuts bolts and clips aren't normally very expensive.
8th Aug 2015 10:43am |
