Home > In Car Electronics (L322) > after contact 12v & inside 12v
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
as for gps, hence my will to put it behind the plastic grill for better signal.
of course the lighter itself doesn't eat anything. I havent been clear but what I meant is that I would connect a cigar plug of this kind
http://www.ebay.co.uk/itm/GRIFFIN-TWIN-2-P...3a70b8f5bc
and then attach a usb cable that goes to the gps tracker
here's my tracker model.
http://www.ebay.co.uk/itm/Real-Time-Mini-P...20fe2344ba 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342469 14th Aug 2015 1:10pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
You could always use a device such as a power magic pro box, that I bought along with my Blackvue. This ensures that the device switches off should the voltage fall below a certain threshold and so not drain the battery! Piggy back fuse off a permanent live supply in any of the fuse boxes. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #342472 14th Aug 2015 1:18pm
Sorry - I thought you were asking 2 different questions.
It looks like it would be fairly low power consumption, but it's not completely clear - it does stage very low power consumption though Thumbs Up
I would be tempted to try to get it in the overhead light space by the sunroof & cable as Craig suggested - I have no idea how much space is in there though....
Post #342473 14th Aug 2015 1:20pm
Ibartsimp
Ok, I just understood that the courtesy mirror proposal was for the gps... 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342474 14th Aug 2015 1:23pm
I had that tracker you linked to above several years ago in a vehicle, it wasn't bad but has an internal GPS and phone aerial, this one is much better and it's what I have fitted... signals are much better even with the aerials buried within the car, it has loads of extra features but if you use it as a straightforward tracker you only need a permanent 12v and an earth.
There is also an app available to send it instructions so you don't have to remember what to text, and a remote to turn it on to save having to text it...
It works just as they say, I have fitted them to every car I've had in the last few years and they have always been reliable and worked fine....
Power consumption is negligible, it won't flatten the battery in two weeks....
http://www.ebay.co.uk/itm/TK103B-GPS-Fleet...19eb0d86eb Pete
Post #342506 14th Aug 2015 4:00pm
miggit
If you are fitting a GPS, it will need clear line of sight to the sky, while you can cover it with the dash board etc, it will not like you much if it has any metal above it, and probably refuse to function. They are normally placed behind the dash below the windscreen, so that it can receive the signal from above without the roof or the bonnet shielding it, Oh and keep it away from speakers Thumbs Up
Look at it like a sat nav, they fix to the windscreen, when they look up there is no metal above them Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #342530 14th Aug 2015 6:11pm
Ibartsimp
Ok thanks for the link, I'll keep you posted about how installation and function of the gps works.
About the plug for the phone, I haven't figured out what i'll do.
Also of interest, where do you fix you phone, do you have pictures?
Thanks 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #342561 14th Aug 2015 8:24pm
