Home > Maintenance & Mods (L322) > Brake pad and disc set for L322 2002 4.4 V8 |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
^ Cheers for the tip DB, but I have chickened out doing this myself this time as I am in the middle of trying to move house, so the car is at the MD at the moment.....cheap as chips...not Mind you much cheaper than the quote to replace the brakes and pads all round......£1400!! SDV8 AB MY 2019
16th Aug 2015 4:02pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
From what i've seen the cooling systems on the BMW units are prone to failure with just about every component - and if you use cheap pattern parts it's even worse! |
16th Aug 2015 8:30pm |
