Home > Maintenance & Mods (L322) > Retrofitting fitting paddle shift to a 2010 5.0 Supercharged |
SCPB Member Since: 16 Jun 2015 Location: Surrey Posts: 72 |
I have started a new thread, just in case it helps someone, although some of this is covered in this thread http://www.fullfatrr.com/forum/topic31125....ddle+shift as it links to the conversion of an earlier car.
12th Aug 2015 8:56pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
12th Aug 2015 11:40pm |
Now if I could just find another 100 bhp....... http://www.fullfatrr.com/forum/topic33317.html
13th Aug 2015 12:41am |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Nice mod
13th Aug 2015 10:25am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3647 |
Watching with interest, I feel another job being added to the list. Geoff |
21st Aug 2015 7:10pm |
That's correct, imagine that you were just about to slide the 4 pin plug in with the notches in the correct orientation but then rotate it through 180 degrees. Check to see if the lights on the paddles (the back lights on the plus and minus symbols) illuminate. If they on, the wiring is likely to be OK so you then need to go back and look at the earlier threads re the software status of the gearbox. 2010 5.0 SC Autobiography |
21st Aug 2015 9:17pm |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 |
SCBP thank you for your reply. The lights are on ok, so do you think ithis an Ecu reflash from the IID tool to update its firmware to activate the paddles.
21st Aug 2015 10:30pm |
Yes it does sound like it, although to be honest I just wired them up, changed the CCF to "fitted" and it worked so the guys on the earlier threads that had the same problem are perhaps best placed to help you with the next stage. 2010 5.0 SC Autobiography |
21st Aug 2015 10:39pm |
Maybe the 2010 built SCs have a software update that allows for the paddle shift to be activated and the 2009 built ones may not have that software bit yet ????
22nd Aug 2015 8:32am |
Have a look at the Powerful UK videos, they are very helpful.
22nd Aug 2015 7:20pm |
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 |
Pretty sure you'll need the ecu update for the paddles to work, so good for the iid, but not so for the Faultmate.
22nd Aug 2015 9:01pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Hi, I just found out this afternoon I have a full set (with matt black trim) of paddle shifters, if anyone fancy them for a better price than new online. Free delivery at the Peterborough show l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
22nd Aug 2015 10:18pm |
So mines a 2009 MY2010 is there a definite way to tell if the paddle shifters can be made to work, there seems to be some doubt - I have an IIDTool. Geoff |
23rd Aug 2015 11:15am |
Pretty sure it can be done but my old one (same year and same MY) needed gearbox ECU firmware flashed. Bodsy can do it with IID though.
23rd Aug 2015 3:00pm |
