Home > In Car Electronics (L322) > Poor FM reception L322 2007 TDV8 Vogue SOLVED |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34925 |
you havnt got a dashcam on the rear window perchance, cos that degrades the fm signal.. ... - .- -.
15th May 2015 10:15pm |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
No dash cam, it's not gonna be easy |
15th May 2015 10:17pm |
i'm running out of ideas now ..... ... - .- -.
15th May 2015 10:19pm |
Needing someone in Manchester area who is a Range Rover audio expert |
15th May 2015 10:21pm |
Well you would not believe it, cause of problem was a f**k**g USB charger that I had plugged into power socket in centre cubby, pure chance i found it, noticed that when ignition key was in accessory position, radio was fine, soon as it was turned to ignition (without starting engine) reception was poo and the same with engine running, I will be smashing offending article with a big hammer, just hope that this will help someone in same position |
3rd Sep 2015 4:22am |
i was pretty close with my dashcam idea , glad its sorted. ... - .- -.
3rd Sep 2015 7:35am |
Oh cool, that's fixed my lousy FM reception in the work hack (Skoda). One of those cheapo dual USB chargers which I was using for the phone and TomTom. Said article now in the bin and a (hopefully) better quality one ordered from Amazon. |
3rd Sep 2015 7:51am |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 |
Same here, wired in a nice little 3amp USB charger under the dash top, coming out right under phone cradle.
3rd Oct 2015 9:04pm |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
My FM reception on some stations has just gone very poor when I switch the rear screen heater. I have a sub charger plugged in but as far as I recall I haven't used the heater with plugged in until the last couple of days when the temp has dropped. I will have to check this and see if that's the cause. |
3rd Oct 2015 9:33pm |
tvrforever Member Since: 09 Feb 2016 Location: Bucks Posts: 53 |
Anybody got a 'known safe brand & model' of USB charging adapter then?
2nd May 2016 6:37pm |
