Home > Technical (L322) > What's this do? (picture inside)
alx
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Nara Bronze
Changing the battery out and discovered this plastic drain hose (hose?) which was loose. Any idea where it's supposed to go? I've tried removing the battery tray but it appears to be secured by two plastic screws that won't move. Don't want to upset something there so would ideally want to tuck the hose away without taking half the car apart... unless I have to?
Post #346082 4th Sep 2015 1:46pm
Balki
Australia
thats just the water down pipe for the wiper arm area, it should just put the water down to the ground under the vehicle
Post #346094 4th Sep 2015 2:23pm
mjdronfield
............from the plug you can see top right in your pic.... I'd move it off the battery tray when you put it back....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #346103 4th Sep 2015 3:08pm
alx
It's pretty obvious what it does Very Happy I was more interested to see where it goes as in if it links to something below the battery tray which I cannot remove. That's fine, I've tucked it in behind the battery for now Thumbs Up
Post #346104 4th Sep 2015 3:25pm
mjdronfield
Sorry, I was just answering the thread title.
Not sure if it connects underneath.....
The fuel burning heater sits under the battery tray on all diesels and on the petrols if that option was chosen. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #346106 4th Sep 2015 3:31pm
alx
That's fine, I appreciate your reply mjdronfield, thank you. Thumbs Up
Mine huffs and puffs in winter so I guess the original owner ticked that option.
Post #346107 4th Sep 2015 3:34pm
Zirconblue
Fuel burning heater is standard on Diesels.
The drain just pokes behind the battery tray, it dumps the water on the the back of the wheel arch liner where it runs off out the bottom. You'll get the idea if you have a look on the other side with a torch, there is just a big hole under the brake servo etc.
Post #346138 4th Sep 2015 6:11pm
alx
Thanks, that's what I did (looked at the other side) but the hose there is longer than this and appears connected/fastened at both ends. I'll leave it like that since it didn't cause any visible issues until now.
Post #346139 4th Sep 2015 6:14pm
