Home > Technical (L322) > Active Locking Rear Differential |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Mine doesn't have one, and if you look at the rear diff there are no wires going to it. So i would think a quick look under the back end would confirm it, if the rear diff has wiring going to it then it's an active one. |
5th Sep 2015 10:26am |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 183 |
So does yours have the same two padlock display as mine? |
5th Sep 2015 12:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
ZB has a 2005 which will have a different setup.....what does the handbook say? ... - .- -.
5th Sep 2015 1:19pm |
Bizarrely enough there is no reference at all to the off road display, and on how to read the wheel position display, etc. |
5th Sep 2015 1:57pm |
theres some info if you search 'locking rear diff'......i found this but i havnt the time [sorry] to read through all the threads..
5th Sep 2015 2:04pm |
That's what I was after! I was clearly using the wrong search words. Many thanks. |
5th Sep 2015 2:57pm |
