Home > Technical (L322) > Active Locking Rear Differential
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
How can you tell if you have a locking rear diff? My MY12 4.4TDV8 shows two padlock symbols in the central screen off-road vehicle information display; one on the transfer box, and one on the rear diff, so does this mean one is fitted or is it generic?
Post #346198 5th Sep 2015 8:28am
Zirconblue
Mine doesn't have one, and if you look at the rear diff there are no wires going to it. So i would think a quick look under the back end would confirm it, if the rear diff has wiring going to it then it's an active one.
Post #346202 5th Sep 2015 9:26am
stoutgoose
So does yours have the same two padlock display as mine?
Post #346210 5th Sep 2015 11:15am
ZB has a 2005 which will have a different setup.....what does the handbook say? ... - .- -.
Post #346215 5th Sep 2015 12:19pm
stoutgoose
Bizarrely enough there is no reference at all to the off road display, and on how to read the wheel position display, etc.
Post #346219 5th Sep 2015 12:57pm
theres some info if you search 'locking rear diff'......i found this but i havnt the time [sorry] to read through all the threads..
http://www.fullfatrr.com/forum/topic20686....+rear+diff ... - .- -.
Post #346221 5th Sep 2015 1:04pm
stoutgoose
That's what I was after! I was clearly using the wrong search words. Many thanks.
Post #346224 5th Sep 2015 1:57pm
