Home > Maintenance & Mods (L322) > Blocked Drain holes |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1227 |
I was looking for the exact same thing this morning, we have the same problem with ours.
3rd Sep 2015 3:44pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 498 |
Seems to be a common fault from what i've read . |
3rd Sep 2015 4:09pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
on my old rr classic, the sunroof used to flood and drip in. there were two small drain holes in the roof tray around the sunroof panel. one was blocked, i found the culprit. it was pinched on the a post inside trim panel. i sort of squashed back to round shape, and tried it with water, and it worked.
3rd Sep 2015 4:45pm |
This is my old one before i fitted Vogue wheels, it used to fill up with water so badly that i ripped the carpets out and removed the floor plugs so it could drain. No sun roof so never found where it got in, maybe tired door rubbers. Ah happy times!!!.
3rd Sep 2015 4:56pm |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 |
Most sunroofs when fully open you'll see a couple of little holes in the corners. An airline down them normally clears them. Must admit not looked at the FF over as not had a problem but really can't be any more complicated, it's just a drain from a low point.. 2003 4.4 Adriatic Blue FF |
4th Sep 2015 11:31am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
Please dont use an airline they can blow off leading to you having to remove the headlining.
4th Sep 2015 1:22pm |
That's a good idea Andy, although I only every use lowish pressure and never had a problem. 2003 4.4 Adriatic Blue FF |
4th Sep 2015 2:45pm |
Thanks Andy, John boy and Lee,
4th Sep 2015 7:33pm |
I did ours today, the passenger side is easy to get to underneath, but the drivers side is hidden under a plastic guard in front of the air reservoir. This panel can be eased out from under the sill, but the valve is a bit fiddly to get at.
5th Sep 2015 1:13pm |
Great result
6th Sep 2015 6:48pm |
The striimmer cable is not really strong enough to get through I found, I was wondering if you can get hold of a can of the compressed air used for cleaning computer keyboards (PCs world I think do it) with an extended nozzle would work better. The sunroof drains are right in the corners. |
6th Sep 2015 6:55pm |
UPDATE
7th Sep 2015 11:08pm |
Well there does not seem to be any more water ingress into the car now! |
13th Sep 2015 9:30am |
13th Sep 2015 6:51pm |
