Home > Maintenance & Mods (L322) > Members BEWARE Winter is coming...
Page 1 of 4 1234>
Members BEWARE!
Winter this year is tipped to be an extra cold affair and i just wanted to remind members (whilst the last of the sunny weekends are here) to look at winterising their FFRR’s...
Coolant should be changed regularly, I do mine every 24 months as it degrades much quicker these days (biodegradable) and with temperatures set to beat those of 2009 some -16 degrees Shocked Shocked Shocked You have been warned...
Don’t forget those other cars too Whistle Wifey’s car, kids cars etc etc Thumbs Up
Post #351973 13th Oct 2015 8:02am
Winter tip No. 2
Check your key blade unlocks the drivers door lock
Post #351976 13th Oct 2015 8:20am
dan_uk_1984
Make sure you apply silicone spray to the door seals after every wash in the winter, especially the felt top door seal that is easily ripped away if it sticks to the door.
Post #351977 13th Oct 2015 8:30am
Gummi for the door rubbers and Lithium grease in the door lock Smile
Also dont forget a decent screenwash mix as while some parts of the screen system are heated it can still take a while to de-ice them.... Also a good chance to test fire the FBH if fitted and ensure its firing up as the park heat is a very nice feature indeed that not many other vehicles have Very Happy
And if you use the hidden menu and your battery voltage is showing lower than it should its best to look at getting a new one at the ready for when it fails in the cold weather...
Also worth noting is having a survival bag in the boot, i hang mine off the netting hook on the passenger side! Things like a lucazade, some snacks, a blanket, gloves, hat, water bottle and backup battery charger for your mobile are worth sticking in and maybe a landy magazine to stave off boredom should you get stuck and be waiting for a yellow taxi Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #351980 13th Oct 2015 8:56am
Time to take off the cover strips on the rear wheel arches, clean up the return flanges and strips, regrease the metalwork and refit the strips for another year of corrosion free wheel arches.
Post #351982 13th Oct 2015 9:15am
..and for those with tractors diesels , get the battery checked out cos any cold will cause you problems if the battery is under par.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #351986 13th Oct 2015 9:38am
mjdronfield
Oh Stan that hurts.....
I was going to suggest a tow rope, but I'm not sure you can use them now..... Think it has to be a solid bar. Rope would get someone out of trouble though..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #352019 13th Oct 2015 12:24pm
Those with petrols will be colder due to hugging their local fuel pumps so much more Rolling with laughter Mr. Green FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #352024 13th Oct 2015 12:50pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Check tyre tread depth, especially on the front wheels.
Just because its the best 4x4 by far, you can still come unstuck (quite literally).
One winter, I wanted to turn left into a side street (frozen slush / compacted snow), turned the wheel and went straight on, just missing a Suzuki jeep that started to pull out, we both stared at each other with open mouths Shocked .
Post #352038 13th Oct 2015 2:51pm
mzplcg
Erm, no. Those of us with the sense to have petrols will also apply the same common sense when selecting an attended service station. Laughing
Post #352039 13th Oct 2015 2:51pm
55palfers
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Santorini Black
Is there we should be starting an annual debate on the merits of; a) winter tyres, b) which brand c) who has some wheels for sale?
Post #352041 13th Oct 2015 2:55pm
mzplcg
Winter tyres are well worth it IMHO, especially when we get below freezing for any length of time.
Post #352047 13th Oct 2015 3:21pm
miggit
Winter screen wash, just use normal dilute-able screen wash and mix it 50/50 with water, don't need that stupidly over priced green stuff. Plus it is a good idea to run a lot through the system paying special attention to the headlamp washers and rear wash wiper,as these are often left with summer mix in them and they freeze solid all winter Evil or Very Mad
Got caught out when that Arctic blast happened a few years back, you know when it all snowed up at the end of October and stayed until March, the headlamp washers on the company Landcruiser froze solid and never worked again, ever Shocked
I can't remember how big the washer bottle is on the ffrr, but I think it's around 4 ltrs in size, so if you were to tip 2 ltrs of concentrate in the system before adding water you wont be far wrong, then it's just a case of flushing it through the system. You can normally tell when it starts to come through as it all gets rather frothy, man Cool
I suppose that the best way to deal with the headlamps is turn them on wash them and then turn them off and on again, otherwise you've got to do 5 cycles before it squirts again Thumbs Up
You've been warned, don't come crying if your squirter gets frozen solid Shocked Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #352051 13th Oct 2015 3:33pm
proser
Is there an alternative to LR antifreeze. I have some OAT in the garage but not sure if it's suitable.
I did check the condition of mine today with a tester and it read that it was good for -37 but not sure how long it's been in there. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #352125 13th Oct 2015 10:13pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
Why is it now that every time someone says "winter is coming" I hear a Yorkshire accent and think of John Snow! Laughing Laughing
Make sure you park your fullfat clear of the black wall, might get scratched. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #352131 13th Oct 2015 11:03pm
Page 1 of 4 1234>
