Home > Maintenance & Mods (L322) > [SOLVED] Not starting like wot it did (but runs OK)
Helping out on a another thread i found this in my list of faults that I never investigated as i wasn't having any problems:
Quote:
“3505 Unknown (Engine)”
Glow plug relay failure - glow relay defective. This one should be investigated if your engine is hard to start when cold.
Time to check this out, seems to make sense as I have a starting up only issue ? .
Post #238021 29th Jan 2014 7:01pm
mjdronfield
Poss worse when the weather is colder then ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #238023 29th Jan 2014 7:03pm
dingg1
Yes - I did ask the question earlier
9 times out of 10 , diesels struggling to start in the winter is either a battery not up to the job or glow plug issues.
Post #238059 29th Jan 2014 9:38pm
May well be the answer...... There is nothing that can't be fixed with a hammer😜😜
Post #238061 29th Jan 2014 9:41pm
It is getting worse, 6/7 chatatas before starting now Embarassed
I read & cleared & read faults with IIDTool and this keeps coming back:
but I have had this as a fault since I got the IIDTool Wink .
Post #238733 1st Feb 2014 2:21pm
dingg1
It'll manage to start ok in the warmer weather
the cold has shown the fault up to be genuine
Post #238749 1st Feb 2014 4:18pm
Not had it in previous years, even when -12 degrees, and it is the same even with a hot engine? .
Post #238763 1st Feb 2014 5:23pm
mjdronfield
I know this thread is like ages old.... Did we find an answer.
Think mines doing the same..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #358331 23rd Nov 2015 7:57pm
Yes, it was two knackered fuel injectors.
I did a leak test to find them (which ones) and Dan at Duckworths happened to have some injectors in a sale of the century.
Leak test and replacing injectors covered elswhere by me on forum. Also my failed attempts to replace glowplugs Shocked still have three new glow plugs available for £15 each Wink .
Post #358359 23rd Nov 2015 9:10pm
mjdronfield
Magic, thanks. That's pretty much what I was thinking then. Started with turning over a bit longer than it should in the summer, so I don't think it's glow plugs.
Will have to get some diagnosis done.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #358364 23rd Nov 2015 9:27pm
