Home > Maintenance & Mods (L322) > Hit standing water fast & hard
holidaychicken
This is up to 05 model, different for later models but same idea
http://www.island-4x4.co.uk/sec000040-disc-shield-p-28306.html
http://www.island-4x4.co.uk/sec000050-disc-shield-p-27984.html
Post #362065 13th Dec 2015 4:22pm
johnboyairey
go to an exhaust kwikfit type centre ask for a free brake and tyre check, they will put it up on a ramp and look for you. you wont be able to look yourself, -but, they should find anything loose etc. tell them the symptoms, and leaning over etc.
then act stupid etc, and drive off!
unless its really dangerous...
Post #362122 13th Dec 2015 11:10pm
Zirconblue
that's true. the large chains wont let you under the ramp yourself. The smaller independent ones on the other hand normally don't mind if you ask nicely. Just go in first thing or any other time they're not busy.
Post #362138 14th Dec 2015 2:10am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
Update on cause : checked everything obvious on Sunday with no luck. Got it on a ramp today and established the heat shied "tin foil" relating to the exhaust situated roughly in the centre of the car had been completely bashed about and was rubbing on the centre propshaft. Took a couple of goes to fix as "tin foil" split and had lost all its rigidity. Seems ok now but suspect a new one will be required. Thanks for everyone's input and looking at how this is designed I suspect this is quite a common issue if someone like me thinks his car can aquaplane like a jet ski. Embarassed 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #362178 14th Dec 2015 2:15pm
What I said Thumbs Up
Post #362184 14th Dec 2015 2:47pm
